820-00165-A Missing PP5V_S4RS3 and PP3V3_S4SW_SNS
  • Flippers McCoy
    Tinkerer
    • Mar 2018
    • 106
    Hello again, everyone!
    I have a MacBook Air motherboard, 820-00165-A that won't boot up. The computer spent an hour on the beach, which was plenty enough to fill it up with sand and/or salt. After that, it showed no signs of life, not even a charging light. I removed the motherboard and cleaned out all the salt, which had caused some damage to J6100 and U7090, so I cleaned up U7090 and just removed J6100. After cleaning I get a charging light which switches from green to orange, but it still won't boot. I also ran it through an ultrasonic cleaner, whcih didn't help. I confirmed that U7090 is working, it's properly outputting PP3V42_G3H.
    PP5V_S4RS3 and PP3V3_S4SW_SNS are 0V. The other S4 rails are fine, but just these two are 0V. Neither of them are shorted to ground.
    I checked on U7501, which creates PP5V_S4RS3 and confirmed that it seems to be working, as U7501 is creating PP3V3_S5_REG_R.
    I checked on U8050 and it's getting voltage in, but is not outputting PP3V3_S4SW_SNS. SMC_SENSOR_PWR_EN is 0V, so I suspect that U8050 is not being told to turn on, but I am unsure of that.
    I've attached schematics and boardview just in case anybody needs them!
    Does anyone have any advice on what to troubleshoot next? I'm at a bit of a dead end from what I know how to do.
    Thanks!
    • 21927
    Re: 820-00165-A Missing PP5V_S4RS3 and PP3V3_S4SW_SNS
    SMC_SENSOR_PWR_EN might be Q5500 shorted or corrosion/smutz
    • Flippers McCoy
      Tinkerer
      • Mar 2018
      • 106
      I checked it out, It's getting 8.6V from PPBUS_G3H, but not SMC_SENSOR_PWR_EN (as expected) and isn't outputting PBUS_S0_VSENSE. Also SMC_SENSOR_PWR_EN isn't shorted to ground (nothing on Q5500 is shorted to ground either). The area looks really good, I've attached a picture just in case, though!
      • Flippers McCoy
        Tinkerer
        • Mar 2018
        • 106
        I checked out those forum posts SMDFlea PMd me (PM me if you would like links), looks like I will likely have to try a reflow of the SMC.
        • PPBUS_G3H is 8.6V solid
        • The traces and probe points near the SPI ROM look great
        • R1300 is 3.4V solid
        • R1301 is 3.25V solid
        • R1302 is 3.2V-3.25V
        • R1303 is 3.3V-3.31V
        • PM_SLP_S4_L is 0V solid
        I'll try reflowing the SMC and see where that gets me
        • Flippers McCoy
          Tinkerer
          • Mar 2018
          • 106
          The reflow didn't do anything, same symptoms. I don't think I have the tools to do a reball, I've been scraping by with a soldering iron, a heatgun, and tweezers :/
          • piernov
            • Jan 2016
            • 4439
            • France
            Ok so to recap, all G3H, RTC and S5 rails are ok but there is no PM_SLP_S4_L? Not even pulsing?
            Check the RTC clock area, check RTCRST#, SRTCRST#, INTVRMEN#, RSMRST# PWRBTN# that go to the PCH.
            • Flippers McCoy
              Tinkerer
              • Mar 2018
              • 106
              I forgot what I measured at each one, so I went ahead and measured them all again and this is what I got
              PPBUS_G3H: 8.56V-8.57V
              PPBUS_S5_HS_COMPUTING_ISNS: 8.56V-8.57V
              PPBUS_S5_HS_OTHER_ISNS: 8.56V-8.57V
              PPDCIN_G3H_ISOL: 18.91V
              PPDCIN_G3H: 18.34V
              PP3V42_G3H: 3.40V-3.41V
              PPVRTC_G3H: 3.31V-3.32V
              PP5V_S5: 4.99V-5.00V
              PP5V_S4RS3: 0V
              PP3V3_S5: 3.31V-3.32V
              PP3V3_S4: 0V
              PM_SLP_S4_L: 0V no pulses
              RTCRST*: 3.30V-3.31V
              SRTCRST*: 3.30V-3.31V
              INTVRMEN*: 3.20V-3.21V
              RSMRST*: 3.27V-3.29V
              PWRBTN*: 3.39V-3.40V
              • Flippers McCoy
                Tinkerer
                • Mar 2018
                • 106
                Bump
                • Flippers McCoy
                  Tinkerer
                  • Mar 2018
                  • 106
                  Bumperooni
                    • 21927
                    Have a good look at all the probe points for liquid damage/corrosion. Have a look at J4800 pin 10
                    • Flippers McCoy
                      Tinkerer
                      • Mar 2018
                      • 106
                      Pin 10 looks a little meh, but it gets continuity between both far ends (the far edge of the pad and the other side of the connector, if that makes sense) and isn't shorted to either of the adjacent pins. Also 18 and 17 look similarly meh, but test fine.
                      I checked out all the probe points and they all look fantastic, golden and shiny
                      • Flippers McCoy
                        Tinkerer
                        • Mar 2018
                        • 106
                        Bump
                        • Flippers McCoy
                          Tinkerer
                          • Mar 2018
                          • 106
                          Bumpitty bump
                          • piernov
                            • Jan 2016
                            • 4439
                            • France
                            No idea, maybe I'm missing something. Any corrosion around the SMC or the PCH? You may try to reflow the SMC, and try to flow some flux under the PCH (if ever the ultrasonic cleaner couldn't clean it all).
                              • 21927
                              Have a good check around the bios chip area.
                              • Flippers McCoy
                                Tinkerer
                                • Mar 2018
                                • 106
                                I already tried a reflow on the SMC, and I just examined it and the surrounding area with a microscope and I didn't see anything off at all. I did find some resistors around U5611 that look a little unhappy, but that circuit only becomes relevant in S0 state, so I don't think that's the issue. I've attached a picture anyway, just in case.
                                I tried reflowing the PCH and adding a pile of flux, and it still has the same behavior except that PPBUS_G3H fluctuates from 20.4V quickly down to 0V then to 20.4V on and on and on.
                                Same thing with PPDCIN_G3H except it only goes as high as 19.04V
                                And, surprise surprise, I'm not getting any more S5 rails
                                • piernov
                                  • Jan 2016
                                  • 4439
                                  • France
                                  Not a great idea to reflow the PCH. However if PPBUS_G3H is now fucked up it should be unrelated. Sounds like bad high-side MOSFET on the PPBUS_G3H regulator or bad PPBUS_G3H controller (the ISL6259).
                                    • 21927
                                    flippers, have you put the order in yet for the Quick 861DW
                                    • Flippers McCoy
                                      Tinkerer
                                      • Mar 2018
                                      • 106
                                      When I put it back on my desk to check out PPBUS_G3H again, it was giving me a steady 8.56V >.>
                                      I checked my power rails again and it's much the same as the last post I made about the state of the power rails, EXCEPT PP3V3_S4 is 3.3V now.
                                      Ah, I didn't know that about the PCH! Why is it a bad idea to reflow?
                                      SMDFlea, there are actually some slightly complicated politics behind the Quick 861DW. Currently I personally don't have the money to buy equipment for myself, nor the time to practice board level repairs as a hobby, as I'm a student working full time. I work in a small computer repair shop full time, and I have been teaching myself how to repair motherboards with the equipment we have on hand as I have the opportunities. Overtime, I have been able to prove myself enough that the owner is comfortable with paying the large amount of money (it's a small shop, we don't have a lot to spare) for the proper equipment. However, I am waiting to hear about another job opportunity this week in the university I hope to attend two years from now.
                                      I would hate for my boss to spend a lot of money on equipment and then have the only employee who knows how to use them leave.
                                      If I do not get the job I am waiting to hear about I will buy the equipment and be much happier for it, if I do get the job I fear that my journey into motherboard repairs may be at an end
                                      Regardless, I should either be getting the proper equipment or stop posting very often in the coming weeks
                                      Thank you for checking up on it!
                                        • 21927
                                        Sorry ,no offence meant.If your journey into motherboard repairs does end I`m sure that the skills you`re picking up now will help you at some point in the future.
                                        • techrepairheide
                                          MacBook Pro (A1502 / 820-3476-A) - No orange/green light and no power
                                          by techrepairheide
                                          Hello again,
                                          got an MacBook Pro from 2015, model A1502 and motherboard version 820-3476-A.
                                          Device died over night on charger.
                                          Currently I did the follow things:
                                          1. Checked visuell the board, test with another MagSafe-Charger and with another DC-IN-board too
                                          2. Measured 16,5V on ​PP18V5_DCIN_FUSE but 0V on ADAPTER_SENSE and 0V on PP_3V42_G3H and 0V on PPBUS_G3H but 16,5V goes to U7090
                                          3. Because of corrosion and bad resistor values I changed these components: U7090 / C7094 / C7095 / R7095 / R7096 / L7095 / C7099 -> But further...
                                          01-26-2025, 05:37 AM
                                        • mon2
                                          A1466 Macbook Air (Liquid damage repair)
                                          by mon2
                                          Hi. Recently serviced a damaged A1466 Macbook Air. Thought to post the issues and resolution for each.
                                          Macbook AIR Model A1466 Diagnostic 09-01-2021
                                          Issue: Liquid damaged (beer spill) Macbook AIR will not power up.
                                          Problems & Resolutions
                                          1) Attached Apple magsafe power adapter. No green / no orange light. This confirms the absence of the PP3V42_G3H voltage rail. The PP3V42_G3H rail is the primary voltage rail necessary to communicate with the magsafe power adapter to report the green or orange light status to the end user....
                                          09-01-2021, 09:31 AM
                                        • speggio91
                                          820-00165 no greenlight in S0 state
                                          by speggio91
                                          I've started to practise more on macbooks air board, I've got a bunch of defective ones, to see if I can gain some more knowledge.
                                          I've been focused on a water damaged board of an 2017 Air.
                                          Someone else already worked on it, the SMC has been reflowed plus some minor reflows around the board.
                                          I've reached a dead end but I improved the state of the board.
                                          Initially it was no power, no green light, no fan spin, stuck at S5 state.
                                          After replacing some components (U7090, Q5500, Q7430, C7432, Q7630, U1950, R6115, R6116,...
                                          11-19-2023, 09:56 AM
                                        • bridges_4u
                                          A1466 820-000165-A with low PP3v42
                                          by bridges_4u
                                          I have got an 820-000165-A motherboard which has got a strange problem. I have 14.32 V at R7005. But when i check pin2 of D7005, it says 0.9V. The diode is OK. Tried changing U7090 too. Any clues?
                                          04-02-2023, 10:47 AM
                                        • m3g4tr0n
                                          820-4924-A - No Green Light
                                          by m3g4tr0n
                                          Have a 820-4924-A - with no Green light on the charger.
                                          R7020 looks discolored and measures 31.9ohms insstead of 47ohm.
                                          attached a picture with voltages between dc jack and u7090.
                                          also getting a short to ground on PP3V42_G3H (L7095, C7099, C7010, C7008, ...)
                                          took off u7090 and L7095, C7099 and short still there. didn't take anything else off.
                                          thanks...
                                          02-09-2021, 06:00 AM
