HP 15-n027sa DA0U92MB6D0 not detecting charger / doesn't turn on
  • loser18
    • Nov 2013
    • 274
    Hey there...
    My problem is as described in title...
    I've got no DC jack light, when charger is plugged in. After presing power button the DC jack LED blinks 3 times and that's it.
    So measured PU2 & PIN6 (ACDET) is only 2.7V...All other voltages on PU2 seems to be OK...
    Voltage on PR55 is 19V on one side & 2.7V on the other one...
    PU2 (BQ24728) voltages:
    PIN1=19V
    PIN2=19V
    PIN3=19V
    PIN4=25V
    PIN5=3V
    PIN6=2.7V???
    PIN7=0V???
    PIN8=3.3V
    PIN9=3.3V
    PIN10=3.3V
    PIN11=2.8V
    PIN12=2.8V
    PIN13=2.8V
    PIN14=0V (obviously AS GROUND)
    PIN15=0V
    PIN16=6V
    PIN17=6V
    PIN18=2.7V
    PIN19=2.7V
    PIN20=19V
    Also tried to re-flash BIOS SPI & replaced PQ16 & PQ17...
    Any help would be appreciated...Thanks
  • Stevie2001
    • Apr 2018
    • 183
    • irland
    Re: HP 15-n027sa DA0U92MB6D0 not detecting charger / doesn't turn on
    Originally posted by loser18
    Hey there...
    PIN1=19V
    PIN2=19V
    PIN3=19V
    PIN4=25V
    PIN5=3V
    PIN6=2.7V???
    PIN7=0V???
    PIN8=3.3V
    PIN9=3.3V
    PIN10=3.3V
    PIN11=2.8V
    PIN12=2.8V
    PIN13=2.8V
    PIN15=0V
    PIN16=6V
    PIN17=6V
    PIN18=2.7V
    PIN19=2.7V
    PIN20=19V
    Best thing is to get your self a dc power supply works flawlessly it is a must bench supply.
    With charger it can inject volts and if anything is blown inside the laptop then it cannot do anything further but with dc power supply it will reverse the power inject the voltage,this way the bad component will heat up and you can use your
    fingers
    freeze spray
    alcohol
    thermal camera
    to spot it and replace it,youtube dc power supply repair learn from it very good to diagnose.
    of course you use the multi-meter but its long process.
    thermal camera is what you can use to find faults using just the original adapter.
    change pu3 ISL6277
    • loser18
      • Nov 2013
      • 274
      THX for reply Steve...
      I've got a professional bench PSU already & do well understand electronics circuitry...The technique you're describing is good for "dead shorted" components, however my issue issue is different...
      • Stevie2001
        • Apr 2018
        • 183
        • irland
        change pu3 ISL6277
        • loser18
          • Nov 2013
          • 274
          Originally posted by Steve22
          change pu3 ISL6277
          You must have wrong schematics as PU3 is different chip in my one...Also ISL6277 got nothing to do with charger detection...
          • Stevie2001
            • Apr 2018
            • 183
            • irland
            your voltage is wrong so isl is main problem.
            PU8
            ISL6277A
            • loser18
              • Nov 2013
              • 274
              can u share shematic
              There's schematic...
              • Stevie2001
                • Apr 2018
                • 183
                • irland
                there's schematic...
                pu8
                isl6277a
                change this guy
                should look like this but pu8 defo
                • loser18
                  • Nov 2013
                  • 274
                  pu8
                  isl6277a
                  change this guy
                  This chip supplies voltages only when mobo is in S0 state & that's completely irrelevant to me...It's got nothing to do with charging circuit...
                  • Stevie2001
                    • Apr 2018
                    • 183
                    • irland
                    try it5
                    this chip controls voltages and if its short then you will get wrong voltages reading in some area or missing voltage.
                    the blinking led comes from this ic
                    • loser18
                      • Nov 2013
                      • 274
                      try it5
                      Replaced just for curiosity but the issue is still the same...
                        • 21984
                        PIN6 (ACDET) is ok .
                        • loser18
                          • Nov 2013
                          • 274
                          So why I've got 3 blinks on DC Jack? I thought it's caused by charger not communicating with charging IC or KBC properly...Also can you PLS share the BQ24728 datasheet?Tried to google but couldn't find it...
                          • Stevie2001
                            • Apr 2018
                            • 183
                            • irland
                            https://www.badcaps.net/forum/showthread.php?t=55032
                            • loser18
                              • Nov 2013
                              • 274
                              Ok...
                              So the issue seems to be KBC (U14) or +3V rail as reads only 1.8V on PIN11 (VCC)...
                              I'm tired AF, so will update tomorrow...
                              • mcplslg123
                                • Jun 2015
                                • 7262
                                • india
                                Have you checked resistance to gnd on vcc pin of kbc?? Something must be pulling the voltage down from 3v to 1.8 v.
                                After a proprer measure you can try removing the kbc and then powering on mb(without kbc soldered) and observe the differences.
                                • mcplslg123
                                  • Jun 2015
                                  • 7262
                                  • india
                                  try it5
                                  Dear Steve, Dont give suggestions which have no logic. Its a technical forum and there is no compulsion for anyone to comment without understanding it and thereby diverting the thought process in troubleshooting.
                                  Dont be offended by my criticism-its in your interest only.
                                    • 21984
                                    Check PU6 and PQ35
                                    • loser18
                                      • Nov 2013
                                      • 274
                                      KBC Voltages:
                                      PIN71=0.8V???
                                      PIN11=1.8V???
                                      PIN74=3.3V
                                      PIN127=3.3V
                                      PIN26=3.3V(assume all other VSTBY have correct voltage)
                                      Resistance on PIN11 is about 114KΩ
                                      • loser18
                                        • Nov 2013
                                        • 274
                                        I was giving you wrong voltage of PIN 11 on KBC...I was reading PIN12 instead...Just checked it under microscope...Really sorry about that...
                                        KBC:
                                        PIN11=0V
                                        PIN12=1.8V
                                        The +3V should be suspend voltage so 0V is correct...
