Aspire 5742G power off after 15 minutes
  • magnetepazzo
    • Feb 2017
    • 85
    • italy
    I have this laptop, when it's power on after 15 minutes approximatly automatic power down immediatly. I have clean the cooling system and change the thermal paste but the problem persist. Suggestion ?
    Thanks to all
  • aleksandra74
    • May 2018
    • 15
    • Srbija
    Re: Aspire 5742G power off after 15 minutes
    Check that the processor and graphics temperatures are good, although you have replaced the paste, maybe the cooling does not work well
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      First, observe whether it shuts down on exact 15 minutes every time. Can you switch it on instantly after shutdown and runs again for 15 mins??
      If it shuts down in exact time every time, then very likely its a bios issue. You need to clean me region in bios. This mb is known to have me region issue.
      • magnetepazzo
        • Feb 2017
        • 85
        • italy
        no after firt power off if i poweron again, shitdown very quickly.I tried to blow with cold air and it works properly, as soon as I stop blowing cold air goes out. I noticed that the fan runs correctly and slowly but before switching off it starts at maximum speed for a second and then turns it off.
        How it's possible to clean region of bios ?
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          If you dont know how to do it, just post your bios here.
          Someone will help you.
          • magnetepazzo
            • Feb 2017
            • 85
            • italy
            This is my dump, how it's possible to clean region of temperature ? thanks
            • caspian
              • Oct 2015
              • 1591
              • Laptop
              have you discovered which component gets hot on the mainboard?
              • magnetepazzo
                • Feb 2017
                • 85
                • italy
                oh yes, but the temperature are good
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  this is not main bios. Post your main bios dump.
                  • Tynan Dill
                    by Tynan Dill
                    Assuming...
                    11-22-2024, 01:46 PM
                  • PantherDave
                    by PantherDave
                    Hi all!
                    05-29-2024, 02:01 PM
                  • Bonaventure Vigil
                    ACER ASPIRE A515-52G CAN ON BUT NO DISPLAY, NO POWER AT VCC_GT
                    by Bonaventure Vigil
                    Dear All,
                    Please really2 need Help on this Acer A515-52G Motherboard Compal EH5AW LA-G521P Rev: 1A.
                    At first this laptop can on, keyboard light on but no display. Open the motherboard, found out the PQZ3 Mosfet and PUZ3 ic near it burn. Refer picture below. Then I replaced both. All the power rail 3.3,5,1.2, 1.35, 0.8V have power back after i turn on the laptop except for the VCC_GT rail. Voltage at Power Supply showing 0.000A before turn on, after turn on it became 0.5 0.6A. Seem cannot boot and still no display. Then I replaced the PUG1 and mosfet, but the VCC_GT still no power....
                    12-12-2024, 10:22 AM
                  • DenK
                    Acer Aspire 5 A514-55 - won't power on, no charger LED, battery not flat - usual suspects?
                    by DenK
                    Dear all, I am trying to troubleshoot an Acer Aspire 5 A514-55 that won't power on. I'll describe the symptoms and my findings so far, and I would like to seek guidance and suggestions on possible suspects in terms of cause/component failure. My initial thoughts are battery charger IC and/or ideal diode/MOSFET (that switches between incoming DC and battery power), but I could be totally wrong on this.
                    1) Laptop was working fine on battery, then user realised battery was running low. Plugged in AC adapter but noticed it was not charging (LED on AC adapter plug did not light). Eventually shut down
                    12-06-2024, 01:29 AM
                    ACER Aspire Aspire X1300 Aspire Specification for Upgrade or Repair
                    This specification for the ACER Aspire Aspire X1300 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Aspire Aspire X1300 boardview and Aspire Aspire X1300 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or...
                    09-12-2024, 03:28 PM
