Ec_agnd signal
  • kadi144
    • Aug 2015
    • 690
    • algerie
    Ec_agnd signal
    hello!
    i need to know what is this signal EC_AGND
    in lenovo G50-70
    THE shematics is here
    https://www.badcaps.net/forum/showth...ighlight=aclu2
    page 44
    THANKS
  • BlueMidnight
    • Jan 2015
    • 489
    Re: Ec_agnd signal
    That is the analog ground for the EC. Digital signals are noisier and can transfer noise to analog signals using the same ground. This is why you will often see separate analog and digital grounds. They have to be connected together on the board somewhere (there can ultimately only be one ground), but it will be on the outside of the chip and not inside.
    • kadi144
      • Aug 2015
      • 690
      • algerie
      Re: Ec_agnd signal
      thanks
      i have the IT8586E very hot and the laptop is dead
      • kadi144
        • Aug 2015
        • 690
        • algerie
        Re: Ec_agnd signal
        i think that is damged
        it s short with the ground
        • BlueMidnight
          • Jan 2015
          • 489
          Re: Ec_agnd signal
          It shouldn't be getting very hot, so yes it might have a short. If it is the only bad chip, it can be replaced. But, the IT8586E has internal memory for the EC firmware. It must be programmed with a special tool.
          • AstutePauciloquent
            Requesting Help For GA-970A-DS3 rev. 1.0, No Post code, no RSMRST# signal
            by AstutePauciloquent
            Hi everyone, over the past few months i have taken a deep dive into motherboard diagnostics and I love the challenge. Currently im trying to learn all about the signals that travel around the motherboard, such as frequencies, enable signals High and Low logic states etc. And i have been learning to read and using the Schematics for this board that i requested here on Badcaps forum, from a few months ago, this is such a great place for these.
            I’ve been working on a GA-970A-DS3 (rev. 1.0) that does not post. This motherboard has been my main learning board. I would like share...
            11-23-2023, 11:02 PM
          • CoinCoin88
            Garage door RX unit (Cardin S38C) does not short relay to send opening signal
            by CoinCoin88
            I'm turning to the Badcaps community to help me troubleshoot the radio Rx card from my (old) garage door opener. While I could just ditch that card and replace the whole system, I first would like to understand "why" it suddenly stopped working, because that's just how I am wired...!
            Some basics: the receiver works on a 30.875 Mhz frequency. Yes, I'm aware this is not in use anymore in a looot of places. It does not use any rolling code, it's just a regular dip-switch code that you have to set up on both the receiver and transmitter. The receiver...
            09-15-2025, 03:36 AM
          • howardc64
            Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
            by howardc64
            Failure Symptom
            No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
            Where is the short?
            Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
            Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
            05-27-2025, 02:56 PM
          • JayPoorJay
            Converting +/- 5v to a Usable Hz Signal
            by JayPoorJay
            Good morning.
            I have posted here before and have gotten AMAZING advise (thank you!). I'm back for more. This BCaps Sub Forum is so well attended I thought I would post here.
            This question is for an automotive application but has to do with what are essentially electrical questions and problem solving... If this is inappropriate I get it. Feel free to delete it or move the question.
            The V 12 Jaguar XJS is notorious for overheating in stop and go traffic in hot weather... Y'all will be potentially helpinh a LOT of people. The solutions and directions...
            08-07-2022, 08:35 AM
          • Scruit
            What is a normal composite signal range for a C64?
            by Scruit
            Hello all,
            Working on my first C64 / Breadbin / 250407. Purchased as non-working. Getting black screen.
            More detail below, but for those that want to get right to the question.... Here are a few waveforms comparing the Pin15 output on the VIC chip (luma/sync) to the pin 4 on the AV socket (composite signal).
            https://imgur.com/gallery/PpqcqPY
            My question is: Is the composite waveform range of 0.1v-1v too low for a c64?
            More detail:
            Symptoms are that that I get...
            04-28-2022, 05:33 AM
