Dell inspiripon 1545 WiFi cannot browse
    This is worrisome , my inspirion 1545 has full WiFi connection but I cannot surf the net with it, I reload the with different OS no luck, change WiFi card, use dell assistant tool, no luck can someone help me out pls
    Re: Dell inspiripon 1545 WiFi cannot browse
    Is there no solution to this problem
      Set the date and time of the computer from the BIOS settings.
      The problem is not in the Wi-Fi card.
      Replace the battery cmos
        Thanks for reply, the time in bios is correct but let me change the change the close and feed u back
          try ipconfig command
            Check your IP address and your firewall
              Thanks for reply, have put the firewall off, changed cmos battery, problem persist it will just browse 2-3 hrs and show no Internet secured
                All the option given didn't surf my problem, so I decided to reload the OS and redrive it, after the it browse for some minute and stop again. Pls I need perfect solution to this dell WiFi issue
                  Have you tried with another laptop on your MiFi ? I've seen similar devices needing a restart after long periods of use.
                    log into MiFi and check settings .. ip something like 198.192.1.1 .. see if it stays logged in after wifi stops .
                      another thing to try is use your phone as a hotspot and connect to that instead of mifi
                        plus you flush the dns to see if that helps ..cant harm nothing trying
                          This looks more like a bad wifi receiver. I had a laptop that acted similar, and the tracert and/or the ping utility, reported packet loss! (IIRC)
                          The wifi card may have a bad solder joint or a bad cap...
                          ASRock B550 PG Velocita
                          Ryzen 9 "Vermeer" 5900X
                          Sapphire Nitro+ Radeon RX 6750 XT
                          eVGA Supernova G3 750W
                          Alienware AW3423DWF OLED
                            With this problem persist
                              Ji have Try 2 Different Working Card,But Problem Persist
