hp g62-a46se cannot power on
  • String2016
    • Nov 2015
    • 2234
    • philippines
    #61
    Re: hp g62-a46se cannot power on
    not good also because 1 pin on the ribbon is missing i just put it just try it but i think is bad also. is there a way to bypass this to make jumper wire from switch board to power button?
    • JaroTech
      • Mar 2015
      • 351
      The only way I know is to replace the ribbon cable with wires, you will need to solder the wires on both boards. More work than just soldering the ribbon cable directly to the motherboard.
      • String2016
        • Nov 2015
        • 2234
        • philippines
        #63
        ok thanks i will try that, so there is no way to bypass like connecting only two wires from switch board to power botton directly?
        • JaroTech
          • Mar 2015
          • 351
          On the power button board, you also have the lid switch, if you don't connect the wires for the lid, you will bypass the function of the lid switch. For the power switch, simply connect with two wires, pin 6 from the button board to pin 6 to the connector on the motherboard, do the same with pin 8.
          • String2016
            • Nov 2015
            • 2234
            • philippines
            #65
            thank you again jarotech for the time and response i will try that tomorrow and give update
            • String2016
              • Nov 2015
              • 2234
              • philippines
              #66
              i tried connect pin6 and pin8 to connector on switchboard and power button board not working cannot switch on.should i directly connect to power button the two wires?
              • JaroTech
                • Mar 2015
                • 351
                Yes, you can try that.
                • String2016
                  • Nov 2015
                  • 2234
                  • philippines
                  #68
                  i already tried still cannot turn on anyone please help how to make jumper to turn on this
                  • String2016
                    • Nov 2015
                    • 2234
                    • philippines
                    #69
                    anyone please help how to jumper this
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      #70
                      If you are confirming that grounding pin125 of kbc switches the mb-You can surely try coonecting pin125 of kbc directly to switch . Remember to connect ground on the other side of the switch.
                      • String2016
                        • Nov 2015
                        • 2234
                        • philippines
                        #71
                        thanks ive done is connect pin6 directly to power button and pin8 on the ground on the other side of the button when plugged in starts automatically display comes and off but when one wire only to pin6 then other wire to ground and the remove it starts normally anyhelp on this
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          #72
                          Have you checked your switch with a multimeter???
                            by sam_sam_sam
                            03-31-2024, 02:12 PM
                            09-06-2024, 05:59 AM
                            HP Pavilion Power 580-187nz Pavilion Power i7-8700 Specification for Upgrade or Repair
                            This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                            09-12-2024, 02:15 PM
                            HP ZBook Power ZBook Power 15.6 inch G9 Mobile Workstation PC Mobile workstation Specification for Upgrade or Repair
                            This specification for the HP ZBook Power ZBook Power 15.6 inch G9 Mobile Workstation PC Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ZBook Power 15.6 inch G9 Mobile Workstation PC boardview and ZBook Power 15.6 inch G9 Mobile Workstation PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on...
                            09-07-2024, 05:20 AM
