hp g62-a46se cannot power on
  • String2016
    • Nov 2015
    • 2236
    • philippines
    I need help on this HP g62-a46se the problem is cannot power on, I checked the voltages 19v, 3.3v and 5v present and 3.3v on power switch present ,but there is no voltages on bios chip.the board id
    motherboard foxconn star federer
    pn: 01013Y000-388-G
    PM_I_HPC_S_MV_MB_V3
    BY FOXCONN
    anyone please help
  • String2016
    • Nov 2015
    • 2236
    • philippines
    Re: hp g62-a46se cannot power on
    anyone help on this please all voltages present but no voltages on pins of bios chip
    • smali
      • Sep 2014
      • 287
      • Pakistan
      Check the board may be it have two bios EC and main bios...find your EC bios chip and reflah it with working dump...and may be you checking voltage on main bios if it has two bios chip then main bios receive voltage after switch on so find your EC (KBC) bios first it it will be 128kb or 256 kb chip.
      • String2016
        • Nov 2015
        • 2236
        • philippines
        thanks for the response yes you are right it has ec bios W25X20BV and main is mx25l3205d, does anyone have a working bios for this model please both main and ec please share
        • String2016
          • Nov 2015
          • 2236
          • philippines
          anyone who has a working bios for this please share
          • String2016
            • Nov 2015
            • 2236
            • philippines
            anyone please help i need a working bios for this model please
            • ala_borbe
              aka Donald
              • 1625
              • Malta
              as always post backup... ec from hp site is 64k so i need your dump to fix it
              Im Back... sort of...
              • String2016
                • Nov 2015
                • 2236
                • philippines
                thanks for the reply alaborbe here it is the original backup EC
                • ala_borbe
                  aka Donald
                  • 1625
                  • Malta
                  here
                  if you have backup of main i can fix dmi data for you
                  • String2016
                    • Nov 2015
                    • 2236
                    • philippines
                    Thanks alaborbe here is the original main dump attached
                    • String2016
                      • Nov 2015
                      • 2236
                      • philippines
                      alaborbe i flashed the file with you bios both ec and main still there is no voltages on MAIN bios chip,I noticed on power button pins PIN12367 have 3.3v and pin 458 have 0v,but when i touch the pin3 with the probe the light comes but not turning on and still there is no voltage on the main bios chip.please help on this
                      • String2016
                        • Nov 2015
                        • 2236
                        • philippines
                        anyone please help
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          This is not a bios issue in my opinion as alaborbe has already given you Official bios to try with. Look further.
                          • String2016
                            • Nov 2015
                            • 2236
                            • philippines
                            thanks for the response but i dont have schematic for this i dont know where to look because ive already checked voltages 19v present 3.3v and 5v present on the coil and on the power switch there is 3.3v on PIN12367, but if i touch pin3 with probe lights on the motherboard comes up but the fan not spinning and there is no 3.3v on main bios chip.
                            • dspok
                              • Jan 2014
                              • 553
                              • Nepal
                              Did you check S2 volatges?
                              • String2016
                                • Nov 2015
                                • 2236
                                • philippines
                                thanks for the response dspok I don't know where to check which part because i dont have the schematics can you help me where to check that please
                                • String2016
                                  • Nov 2015
                                  • 2236
                                  • philippines
                                  anyone please help if i touch with the probe on pin3 on the power switch lights on the motherboard present but not turning on and when i removed the probe from pin3 lights goes off
                                  • JaroTech
                                    • Mar 2015
                                    • 351
                                    What voltage do you have on pin3 of the power switch? You should have +5V.
                                    • String2016
                                      • Nov 2015
                                      • 2236
                                      • philippines
                                      thanks for the response jarotech it has 3.3v
                                      • meritosari
                                        • Oct 2010
                                        • 774
                                        • Indonesia
                                        Schematic?
                                        Check this link. https://www.badcaps.net/forum/showthread.php?t=46245
                                        Try search on google with keyword "PM_I_HPC_S_MV_MB_V3" then the result directly goes to badcaps.net
                                          03-31-2024, 02:12 PM
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                          09-06-2024, 05:59 AM
                                          HP Pavilion Power 580-187nz Pavilion Power i7-8700 Specification for Upgrade or Repair
                                          This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                          09-12-2024, 02:15 PM
                                          HP ZBook Power ZBook Power 15.6 inch G9 Mobile Workstation PC Mobile workstation Specification for Upgrade or Repair
                                          This specification for the HP ZBook Power ZBook Power 15.6 inch G9 Mobile Workstation PC Mobile workstation can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ZBook Power 15.6 inch G9 Mobile Workstation PC boardview and ZBook Power 15.6 inch G9 Mobile Workstation PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on...
                                          09-07-2024, 05:20 AM
