hp g62-a46se cannot power on
    Re: hp g62-a46se cannot power on
    not good also because 1 pin on the ribbon is missing i just put it just try it but i think is bad also. is there a way to bypass this to make jumper wire from switch board to power button?
      The only way I know is to replace the ribbon cable with wires, you will need to solder the wires on both boards. More work than just soldering the ribbon cable directly to the motherboard.
        ok thanks i will try that, so there is no way to bypass like connecting only two wires from switch board to power botton directly?
          On the power button board, you also have the lid switch, if you don't connect the wires for the lid, you will bypass the function of the lid switch. For the power switch, simply connect with two wires, pin 6 from the button board to pin 6 to the connector on the motherboard, do the same with pin 8.
            thank you again jarotech for the time and response i will try that tomorrow and give update
              i tried connect pin6 and pin8 to connector on switchboard and power button board not working cannot switch on.should i directly connect to power button the two wires?
                Yes, you can try that.
                  i already tried still cannot turn on anyone please help how to make jumper to turn on this
                    anyone please help how to jumper this
                      If you are confirming that grounding pin125 of kbc switches the mb-You can surely try coonecting pin125 of kbc directly to switch . Remember to connect ground on the other side of the switch.
                        thanks ive done is connect pin6 directly to power button and pin8 on the ground on the other side of the button when plugged in starts automatically display comes and off but when one wire only to pin6 then other wire to ground and the remove it starts normally anyhelp on this
                          Have you checked your switch with a multimeter???
