x453ma motherboard, turns on and off inmediatly
  • iplaypty
    • Aug 2017
    • 47
    • FLORIDA
    I have this board, x453ma rev 2.0
    Power LED turns on and off inmediatly after pressing power button.
    I measured all the voltage on UP1589Q, attached image.
    How may I know if this IC is ok?
    No voltage (3.3v, 5v) on output coils.
    Any help or tips on this is very much appreciated.
    Thank you
  • JaroTech
    • Mar 2015
    • 351
    Re: x453ma motherboard, turns on and off inmediatly
    Hi, if you have the schematics for the X453MA motherboard, you can share it here, it will help us answer your question.
    • speedycomp
      • Dec 2017
      • 5
      • Serbia
      check voltage on pin 11 ,if not persist , fallow to the source
      • speedycomp
        • Dec 2017
        • 5
        • Serbia
        if exist , found jumpers on motherboard and take out contact to the 3,3 v and 5v . If something have short circuit , after jumpers take out , u will have both voltage .also check all usb input , probably is broken inside and make short circuit inside connector , also check HDMI connector for same reason
        • iplaypty
          • Aug 2017
          • 47
          • FLORIDA
          I do not have the schematics. I found a repair guide on internet, but don't know how to use it.
          • iplaypty
            • Aug 2017
            • 47
            • FLORIDA
            Voltage on pin 11 is 19.4v, stable 19.4v
            • iplaypty
              • Aug 2017
              • 47
              • FLORIDA
              What do you mean by "jumpers on motherboard and take out contact to the 3,3v and 5v"?
              I haven't been able to find any short, USB ports and HDMI ports look in very good conditions
              • JaroTech
                • Mar 2015
                • 351
                From the voltages you have taken on the UP1589Q, two signals are not good ENTRIP1 and ENTRIP2 must be lower than 4.5V to activate channels 1 and 2. If they are higher than 4.5V, channels 1 and 2 do not work. If you look at the repair guide on page 2, you have two signals controlling the UP1589Q, 5VSUS_ON and 3VSUS_ON, these two signals control ENTRIP1 and ENTRIP2 with two transistors in a single 6-pin package, you will find this chip near the UP1589Q, maybe you'll see the K1 mark on it. Measure all the voltages of this chip.
                • iplaypty
                  • Aug 2017
                  • 47
                  • FLORIDA
                  This is what I was able to measure
                  • iplaypty
                    • Aug 2017
                    • 47
                    • FLORIDA
                    I tried to follow the Repair Guide.
                    The charger is pluged-in, no charging light, now power on, power button has 3.3v, 0v when power button pressed.
                    steps:
                    1.Pr8806 AC_BAT_SYS = 19.4v
                    2 PSL8100 +5VA = 4.98v
                    3 PSL8101 +3VA = 3.27v
                    4.R3042 AC_IN_OC# = 0v
                    5 SL3005 +3VA_EC = 0v
                    6 D3204 EC_RST = 0v
                    7.PQ8108 +5VSUS_ON = 0v
                    8 PQ8108 +3VSUS_ON = 0v
                    Could it be the ITE IC? how may I properly check it?
                    • smali
                      • Sep 2014
                      • 287
                      • Pakistan
                      Check short circuit on 3vsus and 5vsus line.
                      • mcplslg123
                        • Jun 2015
                        • 7262
                        • india
                        +3va_ec is zero-means ec is not getting power. So ec will not work. Look for shorting in 3va ec line. Might be sio itself is bad.
                        • iplaypty
                          • Aug 2017
                          • 47
                          • FLORIDA
                          I desoldered PL8101 and was able to get 3V in 3VA_EC and EC_RST.
                          • iplaypty
                            • Aug 2017
                            • 47
                            • FLORIDA
                            Found the boardview, no schematics tho.
                            • iplaypty
                              • Aug 2017
                              • 47
                              • FLORIDA
                              Found that AC_IN_OC# is 0v
                              CHG_ACOK_r_10 is 3v.
                              Changed PR8829 for another 100kohm resistor, no difference.
                              • JaroTech
                                • Mar 2015
                                • 351
                                I have a schematic with components similar to the X453MA, you can use it to troubleshoot. Follow the signals on page 98.
                                • iplaypty
                                  • Aug 2017
                                  • 47
                                  • FLORIDA
                                  Removed PQ8810, now AC_IN_OC# is 3.3v
                                  +3VA_EC is 3.3v
                                  EC_RST is 3.3v
                                  • iplaypty
                                    • Aug 2017
                                    • 47
                                    • FLORIDA
                                    Thank you!
                                    • aris_prast1
                                      • Jan 2014
                                      • 70
                                      • Indonesia
                                      Its solved?My laptop is same...
                                      • iplaypty
                                        • Aug 2017
                                        • 47
                                        • FLORIDA
                                        not yet
                                        • samaelvonhell
                                          Acer Nitro 16 AN16-41 motherboard: DAZGUMB1AD0 turns off after 60 seconds
                                          by samaelvonhell
                                          Hello. Could anyone help me with that problem.
                                          Laptop model: Acer Nitro 16 AN16-41
                                          It had liquid contact and owner dried it up. Dried it so hard that keyboard is all wavy...
                                          I've found one drop on motherboard near B+ capacitor, it wasn't short.
                                          But motherboard works exactly 60 seconds and turns it self off. Not overheating just exactly 60 seconds. Normally I would say its ME Region problem, but CPU is AMD...
                                          In case im attaching BIOS backup
                                          08-01-2024, 08:11 AM
                                        • nieljosiah
                                          HP Notebook - 15-ba017ax (LA-D711P Motherboard) turns off randomly after some time
                                          by nieljosiah
                                          I've had this laptop for 8-9 years, and about a week back, it started malfunctioning. When I press the power button, the power LED comes on for about 5secs and turns off. The fan also doesn't spin at all during this time. But, if I press the power button, and then manually spin the fan, the laptop boots up and the fan starts spinning on its own. Even if I do this, and the laptop boots up, it turns off (hard shutdown) after some time between 10secs and 1hour randomly. I've tried checking the fan voltage and it's at zero volts when I press the power button without spinning it, but when I spin the...
                                          08-17-2024, 02:19 AM
                                        • glovecaps
                                          Asus ROG Strix Scar G533qm with a G733qm Motherboard, can I modify the Bios to accept G533 Bios
                                          by glovecaps
                                          I have a Asus ROG Strix Scar 15 (G533QM) that had a dead motherboard (Graphics card dead) and after trying to fix the motherboard with no success, I bit the bullet on a sale for a new motherboard. I ordered a motherboard for the 15 inch model which is the one that I have, and when the motherboard arrived it wasn't for a little while that I saw it was from the 17 inch model.
                                          My question is, can I update the Bios on this G733 motherboard to a G533 Bios.
                                          The reason for wanting to do this is that the keyboard isn't working as it should, and I think this...
                                          11-25-2024, 04:23 PM
                                        • Docus
                                          Legion Y540 17irh motherboard issue ( need help to know how to diagnose my motherboard)
                                          by Docus
                                          Hi everyone 😀,
                                          I'm here today to ask for help with repairing the motherboard of a Lenovo Legion Y540 17IRH.
                                          To give you some context, I'm passionate about computer repair so much so that I've invested in a lot of tools and started practicing on dead and old hardware. I've been learning how to solder and desolder components, mostly focusing on phone repairs.
                                          Recently, I bought a broken Lenovo Legion Y540 17IRH for just €150, and there are two main reasons why I made this purchase:
                                          1. I already own the exact same model, but its plastic chassis is badly damaged.
                                          06-10-2025, 04:24 PM
                                        • acedogblast
                                          by acedogblast
                                          11-02-2024, 05:13 PM
