problem with svod2
  • menshawy
    • Aug 2013
    • 399
    • egypt
    problem with svod2
    hi all
    i am new user for svo2 programmer
    my problem with programmer with ite io i cannot read the ic
    i try to program ic on mb nm-311a lenovo g50-30
    any one can help me
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: problem with svod2
    Originally posted by menshawy
    hi all
    any one can help me
    Are you trying to read original ite chip or have you replaced it??
    If you have replaced it8586, then its a common problem of getting this error-ITE series not detected.
    I have alreday posted a solution for this problem in this forum.
    You need to press power switch once, and then try to read it(Pressing of switch after connecting all connections with programmer and with adapter connected as well). Now read and it will read like a charm.
    This happens only with so called new ITE8586 sio
    Hope, it helps you.
    • menshawy
      • Aug 2013
      • 399
      • egypt
      thanks friend
      i was read your post but when i press power switch the mb switch on then shutdown quickly and program hang i think that coz 5v form usb short with gnd of programer
      i will try connect gnd with another way
      thanks for help
      • menshawy
        • Aug 2013
        • 399
        • egypt
        good friend your method is right the problem in my mb i try with another mb and svod2 working fine .read and write ec file
        thanks for your help
        • Th3_uN1Qu3
          Believe in
          • Jul 2010
          • 6031
          • Romania
          The programming pins on KB9012 are multi-purpose, on some mainboards they are loaded down by other devices and the programmer can't connect.
          That is why some programmers have breakout board for KB9012 where you desolder it from mainboard and place it on adapter board for programming. It is one extra step and you have to be careful, but on some mainboards it is the only way.
          A working TV? How boring!
            Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) V 10 Specification for Upgrade or Repair
            This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
            09-06-2024, 05:30 AM
          • Natob82
            Micro Momentary Push Switch?
            by Natob82
            Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
            12-21-2022, 05:22 AM
          • theone111
            by theone111
            3. Problem: TV shuts down
            07-22-2024, 10:36 AM
          • grimacelord
            NEC TurboExpress On/Off Power Switch Replacement Help
            by grimacelord
            I've been working on a NEC TurboExpress and I accidentally got the plastic inside the power ON/OFF switch too hot while doing other repairs and melted it. At first, it would still power on when sliding the switch, but you had to really press inward while sliding to get it to work.
            I removed the switch component and tried to gently melt the plastic back so it would work more reliably and all I managed to do was make it worse.
            I need to find a replacement On/OFF switch for this, but having some trouble figuring out which kind of switch I need....
            11-09-2023, 09:49 AM
          • SluggerB
            Help making a switch work the opposite way with a relay
            by SluggerB
            I have a very small float switch, I'm using in a very small tank. It only fits in one way. Link https://www.amazon.com/uxcell-Switch.../dp/B07DZ1J2GB
            I want the switch to be open when the water is high, and closed when the water is low. Unfortunately it works the opposite. And since this switch is designed to be underwater, it's all sealed up, there is no taking it apart or hacking it up.
            It will be driving a water pump, basic idea, when the water is low, switch closes, which turns on water pump, when enough water is in the tank, float switch floats,...
            02-07-2025, 07:57 PM
