HP 19 All-in-one, White charger light on, Does not power on.
  • Blacktek
    • Nov 2014
    • 250
    Hi guys, I have this Computer that is getting power all over the board, even at the power button connection, i did a very good inspection with Microscope but still could find anything out of the ordinary, No water damage.
    I even removed the power jack and still nothing.
    Any suggestions?
  • tibd
    • Oct 2014
    • 189
    • Sweden
    Re: HP 19 All-in-one, White charger light on, Does not power on.
    reflash bios.
    • Blacktek
      • Nov 2014
      • 250
      wow, its weird how bios can cause this.. Can it be flashed using usb? or do i have to find a dump and program it?
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        You need to find a dump and program it with a spi programmer. Check hp site for bios.
        • Blacktek
          • Nov 2014
          • 250
          Ok thanks, only things is HP website all has .exe files, how do i get a .bin from that?
          • mcplslg123
            • Jun 2015
            • 7262
            • india
            Post your old bios here with complete pc model number and mb markings if any. I'll try to help you.
            • Blacktek
              • Nov 2014
              • 250
              Here you go. Markings on chip:
              Winbond
              25Q32FVSIG 1412
              Board markings:
              AMPKB-PT
              Rev:1.02
              • Blacktek
                • Nov 2014
                • 250
                Check it out, above this post.
                • Blacktek
                  • Nov 2014
                  • 250
                  Could this possibly be the SIO it8528e?? How do i check this chip to see if its working correctly?
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    Your bios backup is almost blank. So either your bios is definitely corrupt or the backup was not proper.
                    Since i could'nt verify your backup bios , still i'm attaching hp official bios you can try.
                    There are 3 types of bios in this series-so might not match-but still you can try.
                    Goodluck
                    • Blacktek
                      • Nov 2014
                      • 250
                      Goodluck
                      Thanks buddy, i will try this bios now, first ill see if i can retrieve more using a different eeprom.
                      • Blacktek
                        • Nov 2014
                        • 250
                        How about this one? i Used a different Programmer.
                        • mcplslg123
                          • Jun 2015
                          • 7262
                          • india
                          backup this time seems ok. Your bios is dai 8004 and i have uploaded dai 8006 which is newer. It should work as long as it is bios issue. If you face win licence and serial number missing then that can be fixed later. But first check whether you get display.
                          • Blacktek
                            • Nov 2014
                            • 250
                            no powe no display, charge/power light from the power brick is ON but when i press the power button nothing happens.
                            • mcplslg123
                              • Jun 2015
                              • 7262
                              • india
                              So not a bios issue. Schematic available for your mb?? If not then pickup another schematic with same SIO and try to check voltages at sio pins. You may get some clue.
                              • Blacktek
                                • Nov 2014
                                • 250
                                Good idea, i have over 20 laptop boards and none have this SIO, ill check the web.
                                • Blacktek
                                  • Nov 2014
                                  • 250
                                  It Happened again on a replacement board!! Ordered new board, installed it and it worked for a few days, Its been a couple of days since i dont turn it on, now i tried to use it but its DEAD AGAIN, SAME SYMPTOMS.
                                  Power all around the board, even the power button. but nothing happens when pressed. this is a replacement board from ebay. it worked for a few days now its dead.
                                  RTC/Coin Cell battery was 2.7v, replaced it but still the same.
                                  PLEASE HELP!
                                  • Blacktek
                                    • Nov 2014
                                    • 250
                                    No one?
                                      • 21922
                                      Have you tried a different power brick. Is it a standard hp latop charger ,with sense pin.
                                      • Blacktek
                                        • Nov 2014
                                        • 250
                                        Bingo!! Bad/Wrong Charger
                                        • serious_electron
                                          Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
                                          by serious_electron
                                          Hello Everyone!
                                          I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
                                          06-28-2025, 02:57 PM
                                        • master_haze86
                                          820-01958-A no power sys led = white when charger is connected.
                                          by master_haze86
                                          Hi everyone.
                                          First, let me preface by saying that I do not have much experience with diagnosing damages in motherboards other than visual inspection and checking simple short to ground faults.
                                          But I do learn quickly, and really want to learn how to properly diagnose motherboard faults. If someone could have the patience to go over this board with me, it would be greatly appreciated.
                                          A customer came into my shop with a A2179 MacBook with an 820-01958-A logic board. The reason for bringing the laptop in is that the laptop stopped turning on.
                                          First thing...
                                          02-15-2024, 05:30 PM
                                        • motormayhem
                                          Lenovo T460 Only Charges on One Charger
                                          by motormayhem
                                          Laptop Question
                                          I'm working on a Lenovo T460 that has been having trouble charging as of late. Its worked well since I've owned it for a few years. When I went to use it the other day it was dead and wouldn't turn on (was sitting on an Anker 65W GaN charger). After some fiddling with the charger I got it to turn on and start charging, but seemed like the charger was not working as it should (took a few plug and unplug cycles to get it to start charging).
                                          A day later it was dead again and wouldn't boot/charge no matter what I did. No lights or anything when...
                                          05-12-2023, 01:46 PM
                                        • sherifu
                                          Macbook Air A1466 Emc 3178 No light charger after spilling liquid
                                          by sherifu
                                          Hello guys, i have an Macbook Air A1466 Emc 3178, board number 820-00165-A and i encountered following problems. At first no light, no power..after opening and cleaning the LCD socket(Red dot under LCD plug and also Orange dot near wifi card)..got light on charger, fan working and chime...Tried several times and working, then short time after dead...next day work again for short time...after removing the board and cleaning the back(rust on components) with alcohol and soft brush, one of the resistor is gone and no power ..I want to change 5 (buy from China) of them (1 missing and 4 bot looking...
                                          03-26-2024, 04:54 PM
                                        • ahoonid
                                          820-00165 Random green light on charger
                                          by ahoonid
                                          Hey everyone,
                                          I have a MacBook Air 2017 with a weird problem. The MacBook was totally dead at first and the culprit was the C7430 capacitor which was obvious upon initial inspection as it had a fracture on its surface.
                                          The F7140 fuse was also blown so I changed them both. L7130 due to corrosion was also replaced. Now everything works again. Laptops turns on and everything seems reliable at this point.
                                          The only issue that I'm afraid might bite me in the ass later is the magsafe light as it randomly changes light from orange to green while charging. Other times...
                                          04-10-2024, 04:06 PM
