HP Sleekbook 15-b003ee Power button flashing Continuously
  • subroto
    • Oct 2015
    • 230
    • Bangladesh
    Help me to recover a HP Sleekbook 15-b003ee.
    MOBO ID: DA0U36MB6D0 REV: D
    (Schematic is attached below.)
    After pressing power button, both power button LED and power LED on MOBO start blinking in a long interval as 5 second.
    I've flashed both EC and MAIN BIOS with known well one.
    Have found MAINON, SUSON, VRON signal is becoming high along with the LED and immediately goes to LOW for 5 sec as the LED.
    3.3V_ALW and 5V_ALW come after pressing power button.
    3.3VLDO and 5VLDO is present.
    I've also changed the KBC/SIO. But still have the same problem.
    If anyone has solved the problem before then please give the case study. If not then please someone help me to find the problem.
    Thanks in advance.
  • subroto
    • Oct 2015
    • 230
    • Bangladesh
    Re: HP Sleekbook 15-b003ee Power button flashing Continuously
    It's urgent. Someone please help.
    • angel-boy
      • 550
      try this bios from here
      https://www.badcaps.net/forum/showthread.php?p=654196
      and try to convert to UMA from here
      http://*******/viewtopic.php?f=53&t=68852
      • subroto
        • Oct 2015
        • 230
        • Bangladesh
        Originally posted by angel-boy
        It's a UMA board.
        • subroto
          • Oct 2015
          • 230
          • Bangladesh
          Someone please help!!!
          • KvnTM
            • May 2018
            • 434
            Have you replaced the ram with known good ones ?
            Is +VCC_CORE present ?
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              The post is one and a half year old my friend
              • KvnTM
                • May 2018
                • 434
                Ha! I didn't notice. Well that's embarrassing
                  • 21880
                  @KvnTM posted because there were 2 posts from november 2019 mentioning the power button flashing.Those posts were spam and have been deleted .
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    Yeh, it happens. just had fun.
                    • STKR123
                      Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
                      by STKR123
                      As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
                      I wonder if re-flashing the BIOS might be of any use here.
                      As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
                      There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
                      11-03-2024, 06:58 AM
                    • themosttogain
                      HP Envy 13-BA1565na with intermittent power button
                      by themosttogain
                      Hope someone can give me some suggestions on this because i'm at my wits end with it...
                      I have an Envy 13-BA1565na here with an Intel Core i7 i7-1165G7 CPU (board is a LA-J475P Rev 1.0) which has an intermittent power button issue. The power button is integrated into the keyboard, and I have ruled out the keyboard, BIOS and battery as being the issue.
                      Basically, on mains power, the power button works fairly well. The first time you come to it after leving it sitting (either on charge or not on charge), it might take 2 or 3 presses of the button, but then the laptop boots...
                      07-12-2024, 03:03 AM
                    • Tynan Dill
                      by Tynan Dill
                      Assuming...
                      11-22-2024, 01:46 PM
                    • dj-bobr
                      Thinkpad W541 (20EG) Q1, weird behavior after SPI flashing (3 flashes of power button LED)
                      by dj-bobr
                      I kindly ask for help with Thinkpad BIOS/ME repair.
                      Thinkpad W541 board bought from Aliexpress, so I have no service tag nor S/N. It is 1GB version Q1 (K1100 nVidia GPU). BIOS 2.23, EC 1.13, ME 9.1.32.1002.
                      It worked fine until I tried to remove whitelist.
                      Steps taken:
                      - battery out, CMOS coin cell out, laptop disassembled; I kept LAN/USB subboard connected
                      - i took SPI programmer (CH341A with 3.3V mod) and SOIC clip and did a full backup of all SPI flash chips (SPI1 and SPI2 - BIOS, EC, ME, GbE; SPI3 - video BIOS; SPI4 - Thunderbolt fw) for several...
                      03-05-2024, 04:28 AM
                    • reessi
                      Macbook Air - 2018 - A1932 - 820-01521-02 - Bootlooping if Power Button Connected
                      by reessi
                      With the power button connected it either boot loops with the apple logo or no display but the charging meter shows it looping on charging every few seconds.
                      No corrosion any where!
                      Tried a replacement power button off ebay and the same.
                      Very occasionally it will work with the power button connected!
                      Same results with or without the battery.
                      Can it be a fault with the Audio board or the mainboard?
                      The touch Id assembly connects through the Audio board first then to the Mainboard.
                      Flex...
                      06-26-2024, 03:31 PM
