help hp probook 6565b
  • new
    • Oct 2014
    • 157
    • canada
    Re: help hp probook 6565b
    well someone on here told me the file on hp is the update file not the full bios file, and i don't have much experience with bios dump files , i'm here looking for an advice not argument , thx however the laptop doesn't power on at all after replacing the bios chip it was powering on with caps lock error blinking code but after flashing the bios it doesn't turn on just has amber light on the battery and whatever you do this light doesn't change even if you plug the battery the light stay steady amber and , measured voltage on the bios chip there's are 3.3V on pins 1,3,7,8 and pin 4 is ground and i test it and it grounded , 19V coming on dc jack and power ic , there's voltage on the battery pins
    • new
      • Oct 2014
      • 157
      • canada
      please read all comments
      I suggest you find a dump file on badcaps.net and write it on the Bios chip.
      so i'm following what others have said on this thread .. does amd board have EC or KBC bios ? can someone pls answer this
      • caspian
        • Oct 2015
        • 1591
        • Laptop
        you are right. this laptop needs an 8MBytes bios dump. but HP provided a 2MByes bios update which is not useful. So try to find a full bios dump of 8MBytes. Unfortunately, nobody provided it on the net yet.
        you said it is an 8MBytes bios chip. I hope you are right. It is useful if you mention the full model of the bios chip. such as w25...
        • String2016
          • Nov 2015
          • 2238
          • philippines
          bios from mcplslg123 is working i already tried now maybe your issue is not on the bios you wasting your time for asking here and create two threads with the same issue.
          • rioreno
            • Feb 2009
            • 540
            • Indonesia
            hp6565b has 2MB bios...
            mcplslg123 post full bios from site..it should be work even no dataDMI...
            i give you backup from board
            if this file not working too,So this is not bios issue check your programmer maybe corrupt file while writing, or change another bios chip , or your check your soldering
            • caspian
              • Oct 2015
              • 1591
              • Laptop
              #26
              this 2MB file seems to belong to MX25L160, but he said he programmed a winbond IC. So maybe his mainboard is different or the mainboard has two bios ICs. It is great if he mension the full model of all the bios ICs on the mainboard and the mainboard code too.
              • rioreno
                • Feb 2009
                • 540
                • Indonesia
                #27
                i agree to makesure..
                Originally posted by new
                tried to reflash the bios to remove the user power on password , it is amd so i believe i just have to flash the main bios right away using the bin rom file from hp website ?? i tried that and all went good through my programmer and verified , then i went to solder the bios chip back to the motherboard when press power button laptop is dead . dpesn't turn pn at all . no lights except the power led light in the front when you get when you plug the charger . there's voltage on all bios pins except no voltage on pin 1 and 8 ??? what am i missing , please advice
                the problem has move from the bios file issue??? pin 8 vcc must 3.3v
                no backup , 8Mbit bios chip , file was 2Mbyte
                8Mbit=1Mbyte
                so the file must be 1mb
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  #28
                  I dont think so this mb has 1mb bios size. As far as i remember, this mb has only one bios chip 2mb-but yeh not 100% sure as these mb hardly comes for repair these days.
                  • new
                    • Oct 2014
                    • 157
                    • canada
                    #29
                    Mobo has 2mb bios chip , pin 8 has 3.3V i measured it
                    • new
                      • Oct 2014
                      • 157
                      • canada
                      #30
                      thx for all the help , i returned the laptop to the customer as i gave up at this point . i don't use this forums much so i might have opened 2 thread by accident , how can i close them ?
                      • new
                        • Oct 2014
                        • 157
                        • canada
                        #31
                        replaced the bios chip after the customer bought it off ebay and all good now . thanks for all the help
                        • JorgeCaceres
                          • Mar 2018
                          • 11
                          • paraguay
                          #32
                          anyone has the schematic for this model?
                          • Oj computer
                            • Dec 2021
                            • 38
                            • Nigeria
                            #33
                            Good day all, I have the same board HP 6565b (AMD) come up on keyboard while pressing cpslock/NumLock key but not display on screen and external monitor.
                            I've reprogrammed but bios same thing.
                            Kindly help.
                            • macabook
                              by macabook
                              🧩 Initial Issue
                              07-24-2025, 02:17 PM
                            • Vesko356
                              by Vesko356
                              08-11-2023, 03:27 AM
                            • the_raz
                              Need (unlocked) bios for HP Probook 450 G3 Notebook
                              by the_raz
                              I'm requesting a bios .bin for 2 of my hp Probook 450 G3's. Both of which I had forgotten the bios passwords. I stupidly flashed both of them with firmware "made" by the RCUnlocker software and I guess I shouldn't have. The last thing I did was flash both of them with RCUnlocker-fw thinking it would 100% work and left my programmer etc behind and won't have access to them for another 2 days so I figured I'd create a thread to see if I'd be so lucky that someone might have a working file laying around 😝
                              Laptop number 1:
                              Model: HP ProBook 450 G3
                              Motherboard part number:...
                              12-17-2024, 03:37 PM
                            • jbonavita
                              by jbonavita
                              Some issues
                              Things I tried
                              04-29-2025, 09:38 PM
                            • zenius
                              by zenius
                              12-08-2024, 06:13 AM
