help hp probook 6565b
  • new
    • Oct 2014
    • 159
    • canada
    tried to reflash the bios to remove the user power on password , it is amd so i believe i just have to flash the main bios right away using the bin rom file from hp website ?? i tried that and all went good through my programmer and verified , then i went to solder the bios chip back to the motherboard when press power button laptop is dead . dpesn't turn pn at all . no lights except the power led light in the front when you get when you plug the charger . there's voltage on all bios pins except no voltage on pin 1 and 8 ??? what am i missing , please advice
  • tibd
    • Oct 2014
    • 189
    • Sweden
    Re: help hp probook 6565b
    bad bios flash bin. get Another bin one or reflash backup to verify.
    • new
      • Oct 2014
      • 159
      • canada
      i measured voltage on the board without soldering the chip and same result
      • new
        • Oct 2014
        • 159
        • canada
        you mean get another bios chip ?
        • new
          • Oct 2014
          • 159
          • canada
          does amd bios file need to be modified or it can be flashed right away . downloaded it from HP website . anyone can advice , thx in advance
          • new
            • Oct 2014
            • 159
            • canada
            tested it again there's 3.3V on pins 1,3,7,8
            • caspian
              • Oct 2015
              • 1591
              • Laptop
              have you made backup of the original Bios?
              what is the model of the Bios chip?
              How much is the size of the new Bios file which you programmed on the chip?
              • new
                • Oct 2014
                • 159
                • canada
                no backup , 8Mbit bios chip , file was 2Mbyte
                • new
                  • Oct 2014
                  • 159
                  • canada
                  it is winbond chip , it was detected fine by the programmer and all went good and verified , does amd probook needs dump file or it can be flashed right away using the official bin file ?? as far as i know you can flash amd bios right away ? can someone confirm or correct me ?
                  • caspian
                    • Oct 2015
                    • 1591
                    • Laptop
                    I suggest you find a dump file on badcaps.net and write it on the Bios chip.
                    • diif
                      • Feb 2014
                      • 6978
                      • England
                      The file on the HP website is just the update not the full files. If you wrote it to the BIOS chip before backing up the original then you must find a dump and write that.
                      • new
                        • Oct 2014
                        • 159
                        • canada
                        i understand that but as far as i know with amd you can take the whole file and flash it .. can someone confirm ?
                        • new
                          • Oct 2014
                          • 159
                          • canada
                          anyone have the bios dump for probook 6565b ?
                          • mcplslg123
                            • Jun 2015
                            • 7262
                            • india
                            This is HP official bios. If it doesnt work then not a bios issue. You can try another bios chip of 2mb size.Might be graphics issue as this series is known to have ati graphics failure.
                            • new
                              • Oct 2014
                              • 159
                              • canada
                              i need the dump file to use it with my programmer not the official one . i already tried the official one it doesn't work .. not a graphic issue . it has AMD A6 processor which it is APU ( cpu + gpu ) combined together into the processor , the laptop will not turn on at all no power the only light on it is the charger light , no respond to power button and this happened after i flashed the bios . thank you
                              • vhn1998
                                • Jun 2015
                                • 56
                                • Vietnam
                                I need code main board
                                • new
                                  • Oct 2014
                                  • 159
                                  • canada
                                  code main board ?
                                  • String2016
                                    • Nov 2015
                                    • 2238
                                    • philippines
                                    check your motherboard there is a board code there
                                    • new
                                      • Oct 2014
                                      • 159
                                      • canada
                                      anyone can provide me with the dump file , once again please don't send me the bios update file it will not work , i need the bios dump file to flash it with the programmer
                                      • mcplslg123
                                        • Jun 2015
                                        • 7262
                                        • india
                                        You are talking funny. The hp official is a full bios. What difference will you get with a dump?? If hp offical bios(which is full) doesnt work-its not a bios issue. Whichever dump you may try, it wont work. You are simply wasting time with flashing. Look for schematic and troubleshoot the signals rather.
                                        • macabook
                                          by macabook
                                          🧩 Initial Issue
                                          07-24-2025, 02:17 PM
                                        • pirati
                                          by pirati
                                          10-27-2025, 04:20 PM
                                          by Vesko356
                                          08-11-2023, 03:27 AM
                                        • the_raz
                                          Need (unlocked) bios for HP Probook 450 G3 Notebook
                                          by the_raz
                                          I'm requesting a bios .bin for 2 of my hp Probook 450 G3's. Both of which I had forgotten the bios passwords. I stupidly flashed both of them with firmware "made" by the RCUnlocker software and I guess I shouldn't have. The last thing I did was flash both of them with RCUnlocker-fw thinking it would 100% work and left my programmer etc behind and won't have access to them for another 2 days so I figured I'd create a thread to see if I'd be so lucky that someone might have a working file laying around 😝
                                          Laptop number 1:
                                          Model: HP ProBook 450 G3
                                          Motherboard part number:...
                                          12-17-2024, 03:37 PM
                                        • jbonavita
                                          by jbonavita
                                          Some issues
                                          Things I tried
                                          04-29-2025, 09:38 PM
