Macbook 820-3115-B help (repair U1800)
  • audiomodder
    • Dec 2017
    • 54
    Hey all,
    First I want to say I am so grateful for this community. All the info and boardview stuff has helped me fix quite a few things already!
    I have one project I'm super stuck on. A very water damaged Macbook 2012 i5 that I am repairing. I got it to boot up and chime with LCD and all (yay! see that repair here: https://vimeo.com/251045518) but now I am stuck because:
    1) It does not see internal SATA HDD (though drive spins up, as does DVD player)
    2) USB seems to work for a second, but then external drive starts making clicking sounds
    3) External FW boot crashes with Kernal Panic
    This is with many different cables, drives, etc.
    Firewire port works and it will boot a drive off there, but usually hangs and goes into kernal panic:
    https://www.flickr.com/photos/158377...posted-public/
    (I can upload a better pic later today).
    It looks like USB / SATA are obviously not working...I think the culprit is going to be a connection to U1800. I don't know where to start though, that chip is massive. I examined the board carefully and things look OK, voltage seems good and I did RAM changes (both slot and card). The only really dubious point is a the PEGCLKRQA_L_GPIO47 signal to U1800. It's a BGA connection to internal trace so I can't do much to check it though :/ It says it's for PCIE though I kind of doubt that is the issue.
    Anyone know where to start? Which clock signals I should check ? Kernal panic seems to indicate USB error...
    Thanks!!
    -Audiomodder
  • ibrahim03
    • Oct 2015
    • 142
    • egypt
    Re: Macbook 820-3115-B help (repair U1800)
    start measured
    PP1V05_S0_PCH_VCCIO_USB
    PP3V3_SUS_PCH_VCCSUS_USB
    PP1V05_S0_PCH_VCCIO_PLLUSB
    PP5V_SUS_PCH_V5REFSUS
    and check port usb vcc 5v .
    look around pch no liquid damaged or missing components
    and Make sure , no liquid damage anywhere
    after all this
    1- reballing pch
    2- change pch
    • audiomodder
      • Dec 2017
      • 54
      Thanks for the reply!! So cool to get help all the way from Cairo
      All the points you mention test OK:
      PP1V05_S0_PCH_VCCIO_USB - 1.04V
      PP3V3_SUS_PCH_VCCSUS_USB - 3.3V
      PP1V05_S0_PCH_VCCIO_PLLUSB - 1.046V
      PP5V_SUS_PCH_V5REFSUS - 5V
      PP3V3_SUS_PCH_VCCSUS - 3.3V
      and check port usb vcc 5v . yep, 5V
      These all seem to be for USB port stuff, though. Since the issue is both SATA and USB, don't you think maybe it is a clock signal?
      I have examined the board very closely with a microscope and see no other missing parts. Water damage is cleaned up very well now too.
      Does anyone know what PEGCLKRQA_L_GPIO47 signal is for? it just goes to a pull-up to 3V3_SUS..
      • audiomodder
        • Dec 2017
        • 54
        UPDATE: WOW, I actually got this thing to boot into the OS using a USB HDD !!! It seems too good to be true....
        Internal SATA is still not recognized, I don't know why. I'm going to see if it will see HDD on the ODD slot, although I think that is SATA II instead of SATA III :/ Tried 4x HDD cables so I kinda doubt that is the problem...though you never know?
        I was thinking of probing the SATA I/O maybe. Chipset on that side of the board is super clean tho (nowhere near the water damage) so I'm still thinking it is a U1800 issue.
        for anyone wondering, I fixed this by:
        1) inspecting and cleaning (flux + reflow) U4650 (USB debugger chip), U9410, U6201, R4650
        2) Cleaning and soldering wire *into* the water damaged vias (including PEGCLKRQA_L_GPIO47), hoping to make internal connections to U1800
        Seems to boot OK now. WOW this is exciting, thank you!! now to just get SATA working (if possible).
        -Audiomodder
        2)
        • audiomodder
          • Dec 2017
          • 54
          FIXED IT!!!
          Turns out all FOUR of my HDD cables were bad...wow. 5th time pulled one from another machine and SATA0 works great! Put everything back together with new RAM and battery and everything boots and runs great. Wow, I can't believe this one got brought back from the dead.
          Thanks for your help ibrahim03!
          • audiomodder
            • Dec 2017
            • 54
            OK, so I jumped the gun a little with all my excitement. Still not perfect.
            After I power up and am running for a few minutes I get the
            "USB Devices Disabled" and it says its shutting off USB ports - when nothing is plugged in! That can't be good.. Does anyone know how / what manages this message for the logic?
            • audiomodder
              • Dec 2017
              • 54
              OK, now I think I got it all going.
              The issue was with U4650 (PI3USB102ZLE) - USB debugger chip. It connects to the SMC and looks for errors on the ports. It's a "critical" part which will keep the system from working if it is missing connections.
              There was the smallest freaking corrosion on pin 4 (SMC_DEBUGPRT_TX_L) which is the output to the SMC. That is why it booted fine but then after looking for a signal for a while, determined there was a fault.
              Ran for a couple hours and plugged / unplugged USB plenty of times. No issue as of yet.
              • sofles
                Macbook Pro 16" A2141 screen artefacts, kernel panic
                by sofles
                Hi there.
                I have Macbook Pro 16" 2019, model number A2141, motherboard number 820-01700. I have some problem with dedicated graphic card. When Macbook switches to dedicated GPU it is getting instantly hot and starts to show glitches on screen, then it freezes (trackpad is not clicking anymore) and shuts down.
                I tried to reinstall MacOS But it was a pain, it started to show glitches in middle of installation and I could not finish it. I only was able to reinstall MacOS when I put Macbook outside (it is winter and -2 Celcius).
                Now situation looks like this, If...
                02-05-2025, 05:05 AM
              • Instafixx
                Macbook A1707 820-00928 Panic Log
                by Instafixx
                Namaste!
                We have a Macbook A1707 which came in for repair. Someone had already tried to work on it and there were traces oh heat and burns on the board.
                The charger was Stuck at 5v and the there was some caps shorted around U3100.
                Turns out there was corrosion under U3100. Same was Reflowed and the Macbook turned on. Works fine but having 1 issue whenever the Macbook is idle and goes into sleep mode. It will WAKE for 1 Second and then do a restart.
                It will Display a Black Screen with error message saying Macbook Restarted because of a problem....
                01-19-2023, 04:15 AM
              • envym
                by envym
                Hi everyone!
                06-27-2025, 08:54 AM
              • Stephen
                MacBook Pro 17" Mid 2010 Kernal Panic Issue
                by Stephen
                So we all know the dreaded Kernal Panic on a 2010 15" and 17" DeadBook Pros. WE know its not the GPU since its the NVIDIA GT 330M series. The thing is this...I replaced the poly cap with a 330 UF capicotr on C9560 and it still kernel panics...so I am like what gives? So I decided to replaced the C9510 with another 330UF Capictor and now it kernel panics faster. So I am lost? I know its not a failing GPU because it boots fine but the moment I try to watch a YouTube video at all the computer black screens and then restarts. Checking the crash report posts towards the error KERNAL TASK....
                05-29-2020, 11:26 PM
              • prw07
                MacBook Pro A2141 - macOS Kernel Panic
                by prw07
                Mac crashes and restarts with kernel panic. No water damage on board. Board is clean. Memtest86 showing no errors. The installation Ventura or Sonoma is successful, but after 5-10 minutes of operation, the accident occurs again. Did a DFU restore and revive, twice with success and successfully reinstalled Sonoma. After 5 minutes of work Mac crashes with Kernel Panic. Apple Diagnostic (AHT) does not find errors.
                How to localize the problem ?
                12-05-2023, 06:57 AM
