Problem with shorted GPU? or just haunted board?
  • BremiX
    • Oct 2017
    • 64
    • Latvia
    so where to begin...
    EA/VA70HW REV 2.0
    Laptop no power, only smoke coming out from area around adapter connector.
    One of two power mosfets where making smoke so I removed it.
    I will add a photo for reference (not my board in photo)
    Connected power supply to adaper connector and board was taking 0.200ish A and fuse "220" did heat up. I replaced it with different "220" but it caught on fire... so I used "2R2" fuse, don't know what's the difference but no fire and no more 0.200 A. Instead it goes from 0.000 A to 0.080 in 6 seconds and stays like that. (did this without having 2nd power mosfet)
    But now when I connect power supply to 2nd mosfet pins I get short and GPU is heating up...
    Why?
    Thank you for your time,
    Raitis
  • ktmmotocross
    Boardkiller
    • Feb 2014
    • 3577
    • slovakia
    Re: Problem with shorted GPU? or just haunted board?
    uu can have shorted high side mosfet of gpu power rail, or reflowed/burned gpu
    • BremiX
      • Oct 2017
      • 64
      • Latvia
      There was a bad AON6428 mosfet, no more short but another problem showed up. Looks like you can't swap 200 fuse with 2R2
      Attached picture, want to know model of that IC.
      edit: I think I found this IC. U8800A BQ24735RGRR 06V370000005
      Battery charging IC.
      • caspian
        • Oct 2015
        • 1589
        • Laptop
        you need a more powerful microscope to read the model of that IC.
        • BremiX
          • Oct 2017
          • 64
          • Latvia
          Eagle eyes!!
          • BremiX
            • Oct 2017
            • 64
            • Latvia
            I can power it on without this battery IC but there is no picture on a screeen only little light flicker...
            • piernov
              • Jan 2016
              • 4435
              • France
              If this was an high-side MOSFET shorted on the GPU power rail, chances are that the GPU is dead… Check first what voltage you get on this line.
              About the charger IC, first check if both DCin MOSFETs are ok, then check if the resistance to ground of the +AC_BAT_SYS line is high enough.
              Check also the current sense resistor R8808 marked R010.
              If everything is ok then the charger IC could be dead, but first measure pins 1 to 11 and 20 to be sure of that.
              • BremiX
                • Oct 2017
                • 64
                • Latvia
                That charger IC is damaged caught on fire
                Removed it.
                Attached photo with mosfet I replaced 1 2 3 pins are 0.88 V but 4th is 1.10V, 5-8 are 19ish V, "330" cap under GPU gets 0.88V another near GPU gets 1.50V.
                So we have fallen Nvidia gpu...?
                Can I disable that GPU and use Intel HD Graphics?
                • caspian
                  • Oct 2015
                  • 1589
                  • Laptop
                  If you find and upload the mainboard's schematics, you get better help to see if the conversion is possible.
                  • BremiX
                    • Oct 2017
                    • 64
                    • Latvia
                    https://www.badcaps.net/forum/showth...ghlight=VA70HW
                    Here it is.
                    • caspian
                      • Oct 2015
                      • 1589
                      • Laptop
                      probably it is possible to convert, but I do not know how. you have to search the Internet to find if someone did it before.
                      • modtool
                        HP Victus 15-FA1025NL , board DAG3PAMB8D0 REV:D, shorted CPU DrMOS and n-mos
                        by modtool
                        Hi to all,
                        the owner of this machine gave it to me after having opened it to take off the dust from the inside, telling me that after that it didn't start anymore.
                        I found that one of the DrMOS (AOZ5016QI) on the CPUCORE was shorted between VIN and VSWH, and that one of the two n-mos connected to the power jack was shorted aswell.
                        I unsoldered the two shorted components and verified that there were no other short circuits, then decided to power the mainboard, firstly with the lab power supply, then with its original HP 200w charger, but the behaviour is the same, the board starts...
                        04-01-2025, 08:22 AM
                      • Dylan Jones
                        MacBook A2681 (Board 820-02862) - UP700 Likely Shorted
                        by Dylan Jones
                        I'm a beginner at laptop repair. I bought a MacBook Air A2681 that doesn’t turn on, just for practice. PPBUS_AON and the other always-on voltages are present and look fine. I did some diode mode measurements and got unusual readings (compared to reference values I found online) on LC320 (44mV) and L82D0 (40mV). LC320 corresponds to the PP5V_S2 power rail, and L82D0 to PP1V25_S2.
                        I injected 1V (current limited to 100mA, the board consumed around 86mA) into PP1V25_S2 to see if anything would heat up, but everything seemed normal. I did the same with 5V (current limited...
                        06-28-2025, 05:07 PM
                      • Yanleb
                        Panasonic TC-P50S1 shorted TXNSC1EDUU (TNPA4782AB) SC Board
                        by Yanleb
                        Hi every one. I just want to share the successful repair of my shorted Panasonic TNPA4782AB SC board.
                        I don't usually do it but so many parts were shorted that I decided to buy the ShopJimmy repair kit instead of sourcing each components individually. Here is the list of components the kit contained, with a remark indicating if I needed that part or not :
                        D608, good
                        D618 RF101L4S, good (See warning 1 below)
                        D619 RF101L4S, good (See warning 1 below)
                        D865 RF101L4S, shorted (See warning 1 below)
                        IC464 Inverter HA MC74HC1G14, shorted...
                        03-09-2020, 12:00 AM
                      • howardc64
                        by howardc64
                        Problem
                        08-04-2024, 10:36 PM
