i need help
  • semsem3ma
    • Jul 2016
    • 13
    • cairo
    i need help
    i have lab top Fujitsu LifeBook LH530
    work ok but no data in lcd
    When I used an external screen it worked good
    i Change the internal screen and the flats
    but the same problem
  • alihomee
    • Dec 2012
    • 1594
    • malaysia
    Re: i need help
    try check cable also....it can be cable or screen or motherboard itself
    • semsem3ma
      • Jul 2016
      • 13
      • cairo
      Re: i need help
      i try another screen and cable but no new
      • Ryan.man
        by Ryan.man
        02-04-2025, 12:23 PM
      • reformatt
        by reformatt
        07-31-2025, 08:37 PM
      • smic717394
        by smic717394
        07-25-2024, 10:16 AM
      • Chrissygizmo
        by Chrissygizmo
        02-10-2025, 12:33 AM
      • spice_disc
        Vizio TV M50-C1 reboot cycle and static on screen
        by spice_disc
        I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
        The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
        09-08-2024, 02:37 PM
