New N12E-GE2-A1 laptop wont install driver
  • Sojke
    • Apr 2017
    • 131
    • Serbia
    Hello, I have an Medion MD98760 with NVidia GeForce GT555M that some times give image some times not, some times random colors and turns off. GPU VCORE was 2ohm to 0ohm.
    Chip is Nvidia N12E-GE2-A1.
    When I replaced the chip with a new one N12E-GE2-A1 VCORE is still 2ohm but laptop does not turn off and installs and boots into windows.
    But now i can not install graphics drivers as the installers do not recognize the chip.
    The chip responds as : PCI\VEN_10DE&DEV_0DC8&SUBSYS_10E717C0&REV_A1
    I have tried reballing it incase it had bad solder balls but the problem persists.
    Is this a video BIOS problem??
    Please help. This is the BIOS file:
  • fester
    • May 2017
    • 158
    • Slovakia
    Re: New N12E-GE2-A1 laptop wont install driver
    check if you have power after mosfet which switch power for GPU.sometimes if GPU die, die also this mosfet..
    • fester
      • May 2017
      • 158
      • Slovakia
      edit: i think faster as read,if you have picture,this is probably not your problem,you can try BIOS but is looks like faulty chip..
      • ktmmotocross
        Boardkiller
        • Feb 2014
        • 3560
        • slovakia
        cracked ball under chip
        • piernov
          • Jan 2016
          • 4435
          • France
          Compare datecode between the old and the new chip.
          Something is fishy there, the device id is not listed as a known ID there : https://pci-ids.ucw.cz/read/PC/10de
          It would be wise to check the NVidia driver INF file to see if the device ID is listed in here.
          • Sojke
            • Apr 2017
            • 131
            • Serbia
            @Ktmmotocross
            The chip behaved the same with its own balls it came with from the factory, and it behaved the same again after re-balling it with fresh leaded balls.
            We have over 100 successfully serviced boards with care via re-balling because of that we are solid it is not an error on our end.
            @piernov
            NVidia driver installer does not detect it nor does manually installing by INF make windows install it correctly.
            Windows accepts it as an GT555M , GT540M and GT635M when manually forced but it always reports error code 43 after restart.
            If this is an faulty chip i need to make sure because only than I am able to file a complain and return it.
            • atsio
              • Oct 2013
              • 819
              • Greece
              What if you let nvidia search your hardware and install the appropriate driver; 0DC8 is NVIDIA Quadro 2000. I think you must have a word with your supplier.
              • Sojke
                • Apr 2017
                • 131
                • Serbia
                Same happens with Quadro 2000M drivers, and NVidia Auto detect does not detect the graphics card.
                I guessed its an unknown device as soon as google did not give me anything for the full name, id, of the card.
                I just don´t know if this can be caused by an old or maybe even bad Video BIOS or some other thing outdated in the System BIOS so I can say for sure it is an defective chip.
                • piernov
                  • Jan 2016
                  • 4435
                  • France
                  Can't find the device id in the NVidia drivers so that's why they won't install. You may have got an engineering sample chip or something like that…
                  I don't think the chip itself is defective, I don't think there is an issue with the BIOS either. Try to replace it with another new and genuine chip.
                  • ktmmotocross
                    Boardkiller
                    • Feb 2014
                    • 3560
                    • slovakia
                    if not cracked solder ball under chip, because of your flawless reballing
                    it must be ball between ic and substrate
                      Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook Specification for Upgrade or Repair
                      This specification for the Microsoft Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum boardview and Surface Laptop 3 13.5-inch i5/8GB/256GB SSD Laptop Platinum schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from...
                      09-06-2024, 09:30 PM
                      Microsoft Surface Laptop Surface Laptop 2 Notebook 2 Specification for Upgrade or Repair
                      This specification for the Microsoft Surface Laptop Surface Laptop 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 2 boardview and Surface Laptop 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      09-06-2024, 08:47 AM
                    • RdeveLabs
                      MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                      by RdeveLabs
                      To all the members here...
                      Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                      So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                      05-05-2025, 04:59 AM
                    • bohaboha
                      how to install gl usb2.0 uvc camera device driver on windows 10
                      by bohaboha
                      Hello all am trying to reinstall my AMCAP Microscope on windows 10 but it is not working anymore. But the cam and the drivers are present in the Device Manager but there it saysWindows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39) the drivers is : gl usb2.0 uvc camera device driver and i also get this mesage: Windows found driver software for your device but encou​ntered an error.
                      but it is quite strange because it did work on this same OS for one week ago and even for sometimes ago on that same but now nix.
                      any help?
                      01-26-2025, 08:33 PM
                      Microsoft Surface Laptop Surface Laptop 4 Notebook 4 Specification for Upgrade or Repair
                      This specification for the Microsoft Surface Laptop Surface Laptop 4 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Laptop 4 boardview and Surface Laptop 4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                      09-07-2024, 06:11 AM
