Quanta U83 liquid damage no power/no display/shuts off
  • piernov
    • Jan 2016
    • 4439
    • France
    I don't remember the laptop model on top of my head, but the motherboard model is Quanta U83, with discrete graphics.
    After liquid damage, the laptop was turning on for 2 seconds after pressing power button, then shutting off. Cause : no CPU VCore.
    I replaced a 1k resistor and ran a jumper between the buck controller and the resistor and I got VCore back.
    Now, the issue is that when the laptop wasn't turned on for an hour, it turns on fine and shows an image but shuts down after a minute.
    If I try to reboot it immediately, it doesn't show an image and the fan gradually spins up, and it eventually shuts down.
    If I try again, it would shut down after a couple of seconds.
    If I try again another time, the charger IC doesn't turn on the main MOSFET and I get no power.
    If I wait a couple of minute, the charger IC works again. If I wait more, I may have get display for a short time again.
    If I bypass the main MOSFET, same symptoms but I get power everytime obviously.
    Liquid damage was found mainly around charger IC and CPU VCore controller.
    With those symptoms I would say I've got an issue with the EC (KB9010), but there was absolutely no liquid there. I may have an issue with the charger IC, but I guess that if I bypass the main MOSFET, the laptop should still boot.
    What do you think ?
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: Quanta U83 liquid damage no power/no display/shuts off
    I had similar symptoms on a liquid-damaged laptop. Finally, I found out the cause was a partially-corroded IC that I ignored to replace. I think it is not the EC in your laptop.
    • atsio
      • Oct 2013
      • 819
      • Greece
      It looks like a problem with a fet
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        This mb is notorious for IO thermal protection. Check that first.
        • rounin
          MacBook Pro A2442 (Board No. 820-02443-05) – Liquid Damage Repair Assistance
          by rounin
          Device Information
          • Model: MacBook Pro 14” M1 Pro (A2442)
          • Logic board number: 820-02443-05
          Original Issue
          The device suffered liquid damage, causing a short circuit on the logic board.
          Near the audio jack area, the CR852 capacitor pad was severely burned, creating a clear short-circuit path. The board could not power on properly.
          Work Performed
          Removed the short circuit by drilling through the board (bypassing the short path) in the CR852 area.
          Current Status
          • When powered on, the screen shows support.apple.com/mac/restore....
          10-20-2025, 11:15 PM
        • mon2
          A1466 Macbook Air (Liquid damage repair)
          by mon2
          Hi. Recently serviced a damaged A1466 Macbook Air. Thought to post the issues and resolution for each.
          Macbook AIR Model A1466 Diagnostic 09-01-2021
          Issue: Liquid damaged (beer spill) Macbook AIR will not power up.
          Problems & Resolutions
          1) Attached Apple magsafe power adapter. No green / no orange light. This confirms the absence of the PP3V42_G3H voltage rail. The PP3V42_G3H rail is the primary voltage rail necessary to communicate with the magsafe power adapter to report the green or orange light status to the end user....
          09-01-2021, 09:31 AM
        • Jenzo
          MacBook A1989 overheating after liquid damage
          by Jenzo
          Hey everyone,
          Had a MacBook pro 13" 2018 (A1989) come in for liquid damage. The only liquid damage was all around UB400. It was most likely soda, so there wasn't that much corrosion. I reflowed the UB400 and the QB chips with some flux, and replaced the caps/resistors that were in bad shape. Seemed to be working fine at first, but the next day when testing it again, the laptop charges and boots fine, the CPU would overheat, and U7210 would get to 70 degrees Celsius as well. I'm testing with only screen and battery connected at this point.
          I can't figure out how...
          05-13-2023, 07:58 AM
        • mitchw
          MacBook Pro 16 M1 Pro Liquid Damage (820-02100)
          by mitchw
          Got a MacBook Pro M1 Pro 16'' to rescue immediately after liquid accident - I got it in less than 30 minutes after the spill.
          It got spilled from behind when the laptop was closed. It mostly affected the rear of the mainboard and the bottom of the LCD.
          I quickly took it apart and washed the liquid residue off the mainboard.
          The area around the UP800 had some light corrosion, but it just washed away with some IPA. Other areas looked undamaged.
          The mainboard got a thorough cleaning, as did the top case and LCD connectors / cables.
          Now the laptop...
          07-16-2025, 07:55 AM
        • larrysito111
          dell alienware m17 r5 LA-L761P liquid damage no image on lcd 2red 7blue runs on external
          by larrysito111
          got here a liquid damaged alienware
          the laptop had damage in the area of the kb9542qf2 all sorted and now laptop working and turns on but i have no display
          so if i start and connect usb-c display it works otherwise it is giving me the 2red and 7blue
          so with the usb-c external monitor is getting to bios and OS
          otherwise not
          so if it is in the os and i connect another lcd via onboard hdmi it is working no problem 2 lcds (1 usb-c + 1 hdmi)
          but still not the internal monitor
          (tested 3V and 5V going to the...
          06-12-2025, 04:16 PM
