Hi ive been asked too look at a relatives laptop i dont work on many so need some advice. So far they have brought and fitted a replacement battery now when they put the charger in and turn the laptop on theirs a error message and the battery will not charge, it says please connect a genuine dell charger at 65 watts etc. I have had a look on the charger it is not a genuine dell one just says replacement charger on it although is the correct voltage and amps etc my guess its the center pin issue? is there any hacks to modify the charger? so it charges the battery or do they need too buy a genuine charger thanks guys.
Dell p17e laptop
Tags: None
Re: Dell p17e laptop
If I remember fine Dell chargers use some kind of ROM inside the power brick connected to the center pin. Don't bother, find a real Dell one. If you ever need to buy them, pick the 90W instead as it will work on most Dell laptops. Some knockoffs can do the job too, but you never know what you'll get with those.OpenBoardView — https://github.com/OpenBoardView/OpenBoardView -
does this one look genuine?
https://www.ebay.co.uk/itm/Genuine-L...72.m2749.l2649Comment
just to update this thread the charger in the ebay link does work fine laptop powers on and charges fine no error messages at all.Comment
by flat-eartherThe charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
Windows also shows ''Plugged in'' when charger is not connected.
This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
If I let battery run out and say it has 3% Windows will... -
Hello Everyone!
I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died....06-28-2025, 02:57 PM -
ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
Highly Integrated Narrow VDC Battery Charger for Notebook Computers
The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
Narrow VDC applications where the system power source is
either the battery pack or the regulated output of the charger.
This makes the max voltage to the system equal to the max
battery voltage instead of the max adapter voltage. Operating
at lower system voltage can improve...-
Channel: Common Parts Library - Datasheets
11-05-2024, 04:43 PM -
by mikey5791Dear all,
Bought this used Dell laptop PP24L(studio 1435) in Jan 2022. It was running smooth on 64 bit Windows 7 pro from processor Intel core Duo T6400@2Ghz with 2GB RAM. The laptop battery was charging and working fine until few months back the opening screen will display something like "replacing the battery warning", press F1 to continue. Normally i press F1, the laptop will proceed to Windows and i can use as normal.
But last week, after i pressed F1, the laptop just shut down. I suspected the laptop battery is dead. So i pulled out the battery and... -
NVDC charger configuration...-
11-05-2024, 03:28 PM -
- Loading...
