C7021 capacitor replacement
  • eNoob
    • Sep 2017
    • 13
    • U.K
    I have a 820-2879-B board. One of the capacitors needs replacing.
    Does it matter which manufacturer to use?
    Could somebody recommend a manufacturer to use for this part.
    C7021
    0.1UF
    10%
    402
    X5R
    25V
    Thanks.
  • caspian
    • Oct 2015
    • 1591
    • Laptop
    Re: C7021 capacitor replacement
    Manufacturer for resistors and capacitors does not matter.
    • eNoob
      • Sep 2017
      • 13
      • U.K
      Thanks.
      • artvandalai
        Where can I get compatible capacitor for replacement?
        by artvandalai
        Blew the capacitor on my analytical balance scale using the wrong power adapter. I need help finding a replacement compatible capacitor to buy. Will any 100uf 40v capacitor work as a replacement?
        12-28-2024, 10:15 AM
      • r2digital
        klipsch kda-500 amplifier suitable power supply capacitor replacement ?
        by r2digital
        I have a klipsch kda-500 that would turn on and allow me to get into the web management but it was picking up a lot of noise from audio sources so i decided to replace the smd caps on the power supply along with radial one. Some one was in here before me and they basically burned the bottom side of the traces off for the radial cap but i was able to repair it without any real problem. I thought i did a good job sourcing out replacement caps but apparently not and now i can't get the power supply to turn on it just constantly try's to keep turning on. Attached is a picture of the power supply before...
        04-18-2024, 03:50 PM
      • rwkish
        Discontinued Capacitor looking for Replacement
        by rwkish
        Capacitor has been discontinued (EGXF101ELL331MM20S) all of the replacements I have found have are smaller than 0.709" Dia (18.00mm). I would like to use the same size or at least close to the same size Capacitor. 19mm would be too big as they would touch and not be able to through hole mount. Tia...
        08-18-2024, 06:54 PM
      • Hylax
        Replacement capacitor options please?
        by Hylax
        Hi, I'm super new to this capacitor stuff but I've some basic soldering experience with old cellphones PCBs and headphones. I have this APAQ AR5K 820∆μF 3V Dc Capacitor from a motherboard that I'm looking to replace, photos I've attached. But I'm unable to find a 3V one like I've marked in the spec sheet in red (This is the one currently present in the motherboard). But the 6.3V one I can find (marked in blue) is of similar dimensions but different specs as mentioned in the table. Is it okay to replace it with higher voltage cap, slightly higher ESR, slightly lower ripple current, and double...
        08-09-2024, 11:25 PM
      • GKdays
        Single capacitor replacement on arcade pcb
        by GKdays
        I have a damaged capacitor from a bootleg double dragon arcade pcb and I have the normal values from it:
        10 volt, 100uF, 85c, but someone from an arcade forum said that the ripple current is not that critical and any good quality low esr cap would be fine, the damaged one is an electrolytic can type but I don't know what to look for as far as low esr is concerned, can a ceramic capacitor be used instead, the capacitor is going to the +5 volt
        I don't know the brand but on the top of the capacitor is stamped "76 F6" if there is a datasheet ide be able to...
        08-09-2022, 05:21 AM
