problem with dell 5321
  • menshawy
    • Aug 2013
    • 400
    • egypt
    i all
    i have problem with dell inspiron 3521 mb la-9104p
    i dont have any 1.5v out from pu300 (rt8207) ihave 5.5v in pin12 on this ic but not any 1.5v get out from it on pjp301
    qz11 was broken an i solder it from the sam mb
    i replace it but the problem dont resolve
    sorry for my bad eng
    any one can help me?
  • petehall347
    • Jan 2015
    • 4445
    Re: problem with dell 5321
    does it get hot ?
    • menshawy
      • Aug 2013
      • 400
      • egypt
      does it get hot ?
      no doesn't get hot
      thanks for your reply
      • toti24
        (NEED HELP)dell precision m4600 problem after bios flash (unbrick)
        by toti24
        dell precision m4600 laptop
        i7 2760qm
        8gb ram 750gb HDD
        intel hd 3000 integraded and nvidia quadro 2000m
        pleasea bear with me english isnt my language and ill try to be as clear as possible
        note i live in mexico in a very small town..
        thank you.
        laptop got bricked (freeze at dell logo) i managed to unbrick it but now am facing a problem...... let me explain what and how it happened.
        the brick happened when i was installing win 10 using usb.
        used rufus and officia microsoft.iso
        it finished copying files from usb...
        03-06-2022, 08:39 PM
      • SDNarcia
        Dell 15R-5521 keyboard problem (KBC?)
        by SDNarcia
        Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
        As additional information,...
        07-20-2024, 10:47 PM
      • Achille15
        Dell N5110 problem
        by Achille15
        so, I have this laptop Dell Inspiron N5110 with a heating problem on both CPU (I7-2680qm) and GPU (GT 525m), I tried many solutions, like changing thermal paste every month, using thermal pads on CPU and GPU, even using thermal pads on CPU nearby coils; but nothing worked, just minutes after booting the laptop shuts itself down so I thought it might be a short problem, so I decided to check what's going on, so I went online and some tutorial (general one) said to check inductors in order to find the shorted circuit, after checking (CPU removed), I found the culprit to be...
        03-29-2025, 04:41 PM
      • masoksian
        Dell latitude e7470 not turn on .power buton on off and Run Power problem
        by masoksian
        I am dealing with the problem of turning on and off my Dell e7470 notebook.
        The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
        The system does not turn on, there is no post.
        I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
        The problem continues in the same way.
        I tried to turn on the Fn key, nothing came to the screen....
        02-15-2025, 12:08 PM
      • MahmoudNasser
        Dell 7480 problem with freezing during the Windows loading process
        by MahmoudNasser
        Hello everyone, I wish you a happy day.
        I have a Dell Latitude 7480 laptop that has a problem with freezing during the Windows loading process. If it manages to boot up, it becomes very slow and doesn't load anything from the desktop.
        Device Data
        Model Dell Latitude 7480
        CPU:i7-7600U
        SN:7T58PL2
        MP PartNumper:CAZ20 LA-E131P Rev:1.0 A00
        Bios Chips:W25Q128BV
        The attempts that have been made to solve the problem have not yielded any results.
        1. Changing the M.2 and M.2 Nvme hard drives.
        2. Trying...
        07-09-2023, 05:04 AM
