Asus EEE PC 1005HA shutting down after power
  • lepak06
    • Feb 2017
    • 51
    • france
    Hi guys,
    i have an Asus EEE PC 1005HA when i press on power button, laptop power and shutting down.
    The Led powering. The fan try to rotate and the hdd make a noise of clicking but can not start.
    I tried to unconect all board (wifi card, power button board, usb board, the hdd, sd slot, and the lcd lvds conector) and i put VGA external and the adapter adapt the motherboard start random. I can access to BIOS. I tried to connect a USB device or an HDD or the LVDS cable and the laptop shutting down.
    i checked voltage on coils, it seems ok i found 3.3v, 5v, 1.8v, 1v, 1.1v
    i heard whistle noise on charger ic.
    What do you think?
  • fester
    • May 2017
    • 158
    • Slovakia
    Re: Asus EEE PC 1005HA shutting down after power
    meassure for short after second power mosfet
    • lepak06
      • Feb 2017
      • 51
      • france
      which second power mosfet?
      is this mosfet in charging section or in" 3.3V - 5V" section?
      thx
      • fester
        • May 2017
        • 158
        • Slovakia
        somewhere on the AC_BAT_SYS line,for example on PR1,no matter which end.
        • petehall347
          • Jan 2015
          • 4427
          • United Kingdom
          try removing the battery
          • lepak06
            • Feb 2017
            • 51
            • france
            the battery is removed
            • petehall347
              • Jan 2015
              • 4427
              • United Kingdom
              not that then .
              • lepak06
                • Feb 2017
                • 51
                • france
                not that then .
                I think The battery is dead, because when i put it the orange led blinking. the battery didnt want charge
                • lepak06
                  • Feb 2017
                  • 51
                  • france
                  i found the problem it was ac adapter
                  When powering laptop the AC_BAT_sys down to 17.8v from 19v before powering
                  i change a 680uF 25v capacitor.
                  Now all ok.
                  thx
                  • GLISIT
                    by GLISIT
                    01-16-2025, 02:29 PM
                  • PantherDave
                    by PantherDave
                    Hi all!
                    05-29-2024, 02:01 PM
                  • ShadowAi
                    ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
                    by ShadowAi
                    Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
                    Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
                    After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
                    03-15-2024, 10:46 AM
                  • meraklinetx
                    Asus Z97-a power cycle, no boot no cpu voltage
                    by meraklinetx
                    Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
                    05-10-2023, 06:08 AM
