qfn mosfet possible replacement
  • Romulo
    • Nov 2016
    • 484
    • Philippines
    hi i need help i cannot find any exact replacement for the qfn mosfet n channel K03J6 1M1 60D7 qfn mosfet can be replaced with?please help
  • Romulo
    • Nov 2016
    • 484
    • Philippines
    Re: qfn mosfet possible replacement
    anyone can help about possible replacement for this mosfet because i dont have exact code
    • khaahk
      • Dec 2013
      • 760
      • Estonia
      https://www.aliexpress.com/store/pro...302033404.html
      • Romulo
        • Nov 2016
        • 484
        • Philippines
        thanks but i already found that i mean that there is any other replacement can get with the scrapboard because if order it takes time to deliver
        • Romulo
          • Nov 2016
          • 484
          • Philippines
          anyone please help if there is available other replacement from this?this from the board of acer aspire e1-471
          • Romulo
            • Nov 2016
            • 484
            • Philippines
            or someone had a schematic on this please share also please
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              SiR474DP is the replacement for K03J6
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Hope this helps Mr. Romulo
                • Romulo
                  • Nov 2016
                  • 484
                  • Philippines
                  thanks for the help mcplslg123 yes its the same i will try to find the replacement for this because i have a lot of scrapboard here maybe i could find that replacement thank you
                  • dj8452000
                    How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
                    by dj8452000
                    I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
                    02-18-2025, 08:28 AM
                  • tmaster21
                    Ideapad 100 NM-A841, P channel mosfet on laptop in.
                    by tmaster21
                    Hello guys. i'm having problems here with this lenovo 110 with board NM-A841 laptop. There is an P channel(pq302) and after it i start ,i have 19v but with time, it decreases or if i press "power on" switch or jumper j6 , it falls to 0 and back to 19v. There is no short and works good on battery, but won't charge or charge until the voltage drop like i explain after P mosfet.
                    Well i suspect that this mosfet is no good. if you look to skematic i have steady 19v on P2 but start to decrease on P3 like if the mosfet is dying . the gate of boot N an P mosfet are the same: is steady...
                    07-17-2023, 09:48 AM
                  • jm942
                    Hp Lh482p 5 short 3 long short after cpu vcore mosfet replacement
                    by jm942
                    My laptop went dead and after checking ,the main 19 volt power rail was shorted. After some checks i could identify that a high side vcore mosfet was shorted.
                    I replaced the mosfet and now the white powerled is present , fans start spinning but capslock shows the famous 5 long and 3 short code.
                    I checked the vcore voltages after replacement and i get for all 1.01 V so means for me that the driver is still working of the replaced shorted mosfet. On the Nvidia i measure around 0.8 V after the mosfets.
                    I did voltage injection on the cpu with 0.7V and i have a current...
                    07-11-2024, 05:11 AM
                  • eccerr0r
                    old X58 triple channel board... memtest86 memory speed?
                    by eccerr0r
                    Anyone run memory speed tests with an old X58-based triple channel 1st gen or any other >2 channel board? The one I have is a Gigabyte I think.
                    Anyway I had four 4GB DDR3-1333 modules in the 6 memory slots and got around 11GB/sec memory speeds assuming that it went dual channel since it didn't have enough modules for triple channel. Now I stuck in two more 4GB modules, but they are DDR3-1600. I'm still getting 11GB/sec speeds according to memtest86...
                    Just wondering, anyone do memory speed analysis on these triple (and higher) channel memory boards? Are there any...
                    06-28-2025, 09:06 AM
                  • String2016
                    SMD MOSFET REPLACEMENT
                    by String2016
                    Hi I need help on this mosfet replacement SM4511NHKPC can I replace this with M3056 OR M3058 please help
                    01-23-2025, 06:35 PM
