Macbook air 11" 2013
  • claudyu07
    Claudyu07
    • May 2014
    • 125
    • Ireland
    Hi. I have a macbook air 11" 2013.
    Symptoms: black screen, no startup chime, fan spinning..stop spinning then spin very fast.
    After bios reset it powers on, chime, apple logo then freeze. Sometimes goes to login screen and freeze. If I switch it off and on again black screen and so on
    Only comes on after bios reset.
    Any ideas?
  • Gigabit2
    MacBook Pro Retina Late 2013 shows light, fan spin but no chime
    by Gigabit2
    I have a MacBook Pro Late 2013 Retina.
    When plugged in, it shows an orange light on the charger (without battery connected) and the fans spin. But after about 15 seconds they stop and then never spin up again. No chimes and nothing on the display.
    There is impact damage to the corners of the casing and one of the USB ports is therefore warped. But the logic board itself looks okay from visual inspection.
    PPBUS_G3H showing 12.58V at all times.
    Can anyone help?
    06-26-2022, 12:05 PM
  • Gigabit2
    MacBook Pro 15" Late 2013 no chime or boot but green light on charger
    by Gigabit2
    I have a late 2013 MacBook Pro 15" here, with light on charger but does not boot with or without battery installed. Can anyone provide assistance?
    I checked these rails:
    PPDCIN_G3H - 19.80 (20V mode)
    PP3V42_G3H - 3.41 (20V mode)
    PPBUS_G3H - 12.56 (20V mode)
    PP3V3_S5 - 3.32 (20V mode)
    These look okay to me, where should I look next?
    05-07-2022, 09:56 AM
  • saulini
    macbook air a1932 no display but can hear the battery chime
    by saulini
    Hello guys...
    I bought MacBook from a garage sale the owner told me that the MacBook was dead and it did not display nothing, at first I thought it was related to a t2 problem so I did the bride OS with my other MacBook I was able to revive it but it did display the apple logo but on the apple configurator the lock symbol was there upon further inspection the MacBook did make the chime sound every time I disconnected the power cable but still it did not show any display also the caps key was able to light up, with nothing else to do i remove the motherboard and found the following...
    09-08-2023, 09:47 PM
  • survivalbloke
    Macbook A1398 - no startup chime, no boot, but have fans and CPU warm
    by survivalbloke
    Macbook A1398 - had repeating loop of startup chime with no actual boot. Just startup chime, then restart, start up chime, then restart, etc. I pulled the battery and cleared BIOS. It will now power up, fans on, CPU warming, but no startup chime and no boot. I reflashed the BIOS chip but the same thing happening. Where should I go from here?
    06-14-2023, 11:45 AM
  • Comp_Pro
    Macbook Air 820-00165 Static Chime Sound
    by Comp_Pro
    Hello all,
    I have a weird issue to solve here. This macbook air came in showing a black screen even though the backlight was lit. The display was not the issue as I tried another known good display. Upon trying to restart it, sometimes it boots up but freezes at the login page. More commonly however, the macbook will give the chime sound but then get stuck repeating the sound. The first chime sound is normal but the subsequent chimes sounds are crackly. Voltages seem normal, no liquid damage. I did find a blotch of something near one of the crystals on the other side of the CPU...
    11-02-2023, 03:23 PM
