hi everyone is there a chance to repair a laptop lcd screen which have no backlight and white screen? if yes can you share it and how please
laptop lcd white screen and no backlight
Tags: None
Re: laptop lcd white screen and no backlight
@ caspian i mean lcd problems we encounter white screen but laptop lvds cable is ok because change new screen shows display. what i mean is if there is a possible to fix a defected lcd screen that has white screen defective problem and the other is no backlight problemComment
I recommend continuing with the white screen.
connect the white screen and turn the laptop on. then measure voltage on all pins of the LVDS connector on the mainboard.
then we can reach some conclusion.
is the external monitor displayed properly?Last edited by caspian; 09-18-2017, 04:44 AM.Comment
most of the times its fuse on lcd which goes bad(White display). Led no light might be a fuse/resistance or the controller itself.Comment
@caspian and mcpslg123 yes it has external display its a lcd panel problem because i try other lcd working fine display working. i just want to ask before a dispose this lcd panel if there is a chance to fix this kind of issueComment
@dellxps15 any model or brand with defective and white screen is there a chance to repair this kind of problem?Comment
I have alreday clarified. If its Lcd, mostly its fuse blown Near Lcd connector on screen(Not on Mb). Applies only when the screen is milky white.Comment
Check panel of lcd where marking vcc, there is a fuse check it is ok or notComment
ok thanks to all for the response your are right i found the problem it is the fuse near the vcc blown i replaced it and its working thank you againComment
by harpTo ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment... -
by dicky96Hi guys, I have an old laptop here I'm just trying to fix for the fun of it really
The top part, maybe 25% or 33% of the screen display works, (DOS boot text or bios screen, I have no HDD fitted) but the bottom part is all white.
On an external monitor connected to the VGA the picture is good.
So basically I have a horizontal division, below which the screen is all white. There is no apparent damage to the screen or any vertical lines
I tried cleaning the pins on the LVDS connector plug/socket as thy looked a bit dirty (18 pins plus... -
by VcemPzdHello everyone !
My name is Chris, I am a 30 years old embedded software developer working in the automotive industry. I am really passionate about learning new skills and repairing/crafting stuff. I came around this forum last week with the goal of repairing my faulty gaming laptop, indeed, I was video editing on it when suddenly a black screen popped and never disappearedI bought some stuff to try to repair it and learn as many things as possible about computer repairs but nothing worked so far. When the black screen appeared, my legion 5 pro was connected to my external monitor...
by EffiSonHi. Could anyone on the forum help me find the cause of the problem?...
The board is LA-B111P Rev:1A comes from Lenovo Y50-70.
I have a identified the damaged R205 resistor, and connect a jump wire over it So it restores the backlight but causing strange problems
1. With Battery ONLY plugged in laptop works fine
2 .With Charger ONLY plugged in laptop works fine as well
3. Connecting both battery and charger at the same time shows a strange flickering screen. The flickering is not constant, it is completely random (and I think it depends on the load -
by ahmarzoI have two laptop hp15- cs1000tx with motherboard part no DAG7BDMB8F0 REV F
First one was not powering on when battery is connected the first n channel MOSFET was short and after changing the laptop started on power and battery and charging fine
Second laptop has water damaged on ram ic after cleaning and changing the ic the laptop is working fine now
But now I have power led continuously blinking 5 times in both the laptop even after shutdown and when it is powered on the led keeps blinking 5 times .both the laptop is charging and working on both battery... - Loading...
