HP Probook 450 G1 charging white LED Continuously flashing
  • subroto
    • Oct 2015
    • 230
    • Bangladesh
    HP Probook 450 G1 charging white LED Continuously flashing after plgging the charger. I've programmed with fresh bios but still same problem. No 15v in run power section. Some days ago I got a probook 4540s with same problem. I couldn't fix that. Anyone here to help me?
    The schematic is attached with a picture of 15v of page no 36.
    The board model is
    Rampage_MB
    12241-1
    48.4YW05.011
  • tibd
    • Oct 2014
    • 189
    • Sweden
    Re: HP Probook 450 G1 charging white LED Continuously flashing
    try Another keyboard and report.
    • subroto
      • Oct 2015
      • 230
      • Bangladesh
      without keyboard it's also showing same thing.
      • fichamba
        • Dec 2011
        • 133
        • Spain
        The board model is
        Rampage_MB
        12241-1
        48.4YW05.011
        Same problem here. If I can fix it, I will comment it here.
        Good luck, in the meantime!
        • mehdiahmadi
          • Apr 2018
          • iran
          i have the same problem
          did you fixit or not?
          • gitsfarmaz
            Professnal tech
            • Apr 2017
            • 30
            • Kenya
            same problem here
            • Mazorca
              • Jan 2017
              • 463
              Can someone explain where or how this 15V is generated? Looks to be related to SPWON.
                • 21597
                That looks like a typing error, it should be 5V_S0 .Look at page 2 of the schematic. SWITCHES , inputs 5V_S5 Outputs 5V_S0
                • Mazorca
                  • Jan 2017
                  • 463
                  That is good to know, that some schematics have typing errors. A while ago, I had one HP schematic with also 15v. Yes, it did measure 5 volts and with no voltage divider I couldn't figure where it came from.
                  Thank you for the learning experience.
                  • rumensat
                    • Apr 2010
                    • 25
                    put 10 kom resistor betwin 18 and 8 pin of RT8223
                    bcose U2605 -temp chip has to have such resistor but dont have and RT can not go main 3.3 and 5 v
                    • forespec
                      • Nov 2012
                      • 14
                      • India
                      I tried 10k resistor but did not work. In my case it works some times itself
                      • acshud
                        • Sep 2017
                        • 106
                        • romania
                        same problem me too.i have 2 motherboard with same problem.some news?
                        • bachir2004
                          • Feb 2015
                          • 439
                          • maroc
                          First try with original charger.Second,have you removed rtc battery?and please
                          you would better start a new thread.
                          • faraday3000
                            • Apr 2020
                            • PerĂº
                            I have the same problem. some news?
                            • pepegotera454
                              • Jul 2014
                              • 15
                              • andorra
                              Diagram page 99, starting sequence indicate what voltages it has.
                              • jembloenx
                                • Oct 2021
                                • indonesia
                                HP Probook 450 G1 charging white LED Continuously flashing after plgging the charger. I've programmed with fresh bios but still same problem. I couldn't fix that. Anyone here to help me?
                                The board model is
                                Rampage_MB
                                12241-1
                                48.4YW03.011
                                • mcplslg123
                                  • Jun 2015
                                  • 7262
                                  • india
                                  Its most probably RTC failure. Probe the RTC Circuit. Usually its a resistor or cap gone bad in RTC circuit.
                                  • STKR123
                                    Elitebooks (820, 840 etc. all gens) and those continuously flashing Power LED + flashing CapsLock LED
                                    by STKR123
                                    As the Elitebooks (820, 840 all gens) only show flashing Power LED and flashing CapsLock (continuously) + a very soft "ticking" noise near the DC Jack,
                                    I wonder if re-flashing the BIOS might be of any use here.
                                    As far as I understood, steady flashing either means insufficient power or a CPU/GPU/Motherboard issue. I use the original 65watt power supply.
                                    There are so many threads out there, but most of the solutions involve flashing codes, which I dont have or claim that you MUST use the original power supply, do a hard reset, reseat the RAM, clean the RAM,...
                                    11-03-2024, 06:58 AM
                                  • GabrielT_03
                                    HP PROBOOK 450 G1 - LED flashing on the charging connector
                                    by GabrielT_03
                                    Please, someone who can help me with a PROBOOK 450 G1. When I connect the charger or power supply, the power jack LED starts blinking. The board has the main voltages: 19V, 3V, 5V, and 3V, and the power button.
                                    The board turns on.
                                    This is the board model: Rampage_MB 12241-1
                                    07-04-2025, 08:54 PM
                                  • Julian Bailey
                                    HP ProBook 445 G8 Battery not charging
                                    by Julian Bailey
                                    Hi all
                                    We have in a HP ProBook 445 G8 laptop with AMD Ryzen 7 CPU. When power is connected the power LED light blinks 5 times then stops. Normally HP laptops will blink this LED 10 times as it does a self test when the AC adaptor is inserted. So there must be some sort of short somewhere.
                                    The battery doesn't charge, and is erratic on the MM voltage. Bench PSU LED pulsates when the battery is connected also. So the fault must be on the charging circuit?
                                    I have gone around the board with a MM and cant find anything
                                    Windows shows the battery fine,...
                                    10-11-2024, 10:34 AM
                                  • coasterghost
                                    Lenovo T14 Gen 2 Type 20XK Model 20XK0069US Odd Charging Issues
                                    by coasterghost
                                    For Badcaps Readers, Please note that I am hopefully going to present this same message to Lenovo to see if they have any insight to the matter as well and figured to share the entirety here for clarification. The System is out of warranty as it is but does have the option to have it extended.
                                    Model Information: T14 Gen 2 (Type 20XK, 20XL) Laptop (ThinkPad) - Type 20XK - Model 20XK0069US
                                    Board: T14 Gen 2 (Type 20XK, 20XL) - Type 20XK.
                                    System Hardware:
                                    Processor: AMD Ryzen 7 PRO 5850U
                                    Memory: 1x 16GB DDR4 3200 (Soldered on Board); 1x Crucial 32GB DDR4...
                                    09-08-2025, 10:46 PM
                                    HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook Specification for Upgrade or Repair
                                    This specification for the HP ProBook ProBook Fortis 14 inch G9 Notebook PC Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the ProBook Fortis 14 inch G9 Notebook PC boardview and ProBook Fortis 14 inch G9 Notebook PC schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...
                                    09-07-2024, 05:50 AM
