PB Easy Note TE11HC Keyboard Not Working
  • passete
    Living=Sharing
    • Jun 2015
    • 487
    • France
    I have received a new KB and same probleme, none of the keys are working.
    It Works well on external usb Keyboard.
    I never had this problem before.
    Any help apreciated
  • mielta
    • Apr 2015
    • 368
    Re: PB Easy Note TE11HC Keyboard Not Working
    Hi
    You must check SIO Chip
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Originally posted by mielta
      Hi
      This kbd not working is a nightmare to me. faced with same issue(some keys not working) on Acer la-7912p & HP 2000 laptop. Could'nt solve it as everything seemed fine. I even replaced Sio and reprogrammed it(For la-7912) but still it was same. I too want to learn on this. keep posted,if you find any solution.
      • passete
        Living=Sharing
        • Jun 2015
        • 487
        • France
        After 20 atempts on connecting and disconnecting the flat cable, the new kb start working.
        very wierd
        Thanks for the tips guys
        • fichamba
          MSI GL75 Leopard keyboard (almost) not working - HELP
          by fichamba
          Hello everybody:
          Let me put all the laptop's info before describing the problem:
          BRAND: MSI
          MODEL No.: MS-17E7
          SKU: GL75 Leopard 10SEK-261XES-BB71075H16GXXDXX
          MoBo: MS-17E71 VER. 1.0
          This laptop arrived to fix the broken left hinge, due to a hit. The hinge was repaired, and when I went to check it out, everything worked well, but I observed certain artifacts (mainly random lines) in the screen.So I decided to remove the screen bezel again, and I saw certain damage to the main LCD harness.
          This time I also observed that the right...
          10-09-2024, 04:53 PM
        • SuperAman
          Keyboard replacement not working issues with Win 10/11 (2) different laptops
          by SuperAman
          I have had an issue that I've never come across in all my years of laptop repairs and it has happened twice in the last couple of weeks. The issue occurred on 2 laptops.
          1. The first laptop a Lenovo Yoga 7 convertible 14 inch 13th gen i7. This laptop came in working, customer wanted to replace the top keyboard assembly for cosmetic reasons so I replaced the keyobard assembly and put their touchpad in it. After booting into windows it would not work, so I assumed I needed to update it or something. Since they didn't give me the Admin account, as it was a company laptop and the...
          08-31-2024, 07:30 PM
        • Vliegenier04
          Macbook A2338 M2 (EMC 8162) keyboard not functioning, trackpad is working
          by Vliegenier04
          Hi! This Mac has been an headscratcher for me, I can't seem to figure out the issue. The Macbook has gotten water damage to the front of the keyboard connector and battery connector. The keyboard connector was dead, by which I mean it was completely corroded and I have replaced it with a brand new one.
          I have verified all the pins are connected to the main board and the main voltages (PP1V8_AONSW_KBD_ISNS and PP3V3_AON_KBD_CONN) are both present, with and without keyboard attached.
          Unfortunately, the keyboard does NOT want to work, caps lock LED not functioning as well as any...
          06-16-2025, 12:03 PM
        • hopkok
          Lenovo Legion 16ITHg6 NM-D721, keyboard not working, LEDs too
          by hopkok
          Hi masters, I need your help.
          I am working on Lenovo Legion 16ITHg6
          Motherboard number NM-D721, no BV, no schematic but I am attaching very closes ones.
          INPORTANT: My motherboard version is with IT8258 IC, that is controlling keyboard and RGB LEDs.
          My problem is on UI142, +3VALW_AG is not stable, floating from 0V to 3,3V.
          AGKB_PWR_EN_N signal is floating too (that is why+3VALW_AG not stable).
          Power LED is not working as well, power button working well.
          UI26 ??? is there any firmware too? Powered by +3VALW_AG.
          Motherboard...
          05-04-2025, 09:35 AM
        • ahmarzo
          MacBook Air a 1466 keyboard and touch not working
          by ahmarzo
          Have a MacBook Air a 1466 with part no 820-00165-a with keyboard and touchpad not working.have tried another working keyboard and touchpad.have check the cable to board and it's good
          The voltage on connector j4800 is following
          Pin no 1-3.3v
          Pin no 10 3.3v
          Pin no 14 - 5v
          Pin no 15-20 all pins have 3.3v
          Have reballed the ic u 5000. And tried another ssd with working os .
          10-18-2025, 10:40 AM
