Hp 15 daor62mb6e1 rev e missing +vcc gfx
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    MODEL HP PAVILLION 15
    M/B- DAOR62MB6E1 REV E
    PROBLEM: Missing +VCC GFX Voltage on PL37 Coil.
    What I have tried:
    01 Flashed both the eeprom with dumps from this forum.
    02 Replaced PU 13/15/16/17
    03. Replaced processor+Ram
    Still same, Laptop switches, fan spins as usual, all voltage rails are present except Vcc Gfx.
    Need your assistance friends.
  • piernov
    • Jan 2016
    • 4439
    • France
    Re: Hp 15 daor62mb6e1 rev e missing +vcc gfx
    Does the laptop seem to boot? CPU_PLTRST#_R present?
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Laptop doesnt boot. CPU_PLTRST#_R Present. Checked at R460/R461. Its 1.1v
      • mcplslg123
        • Jun 2015
        • 7262
        • india
        I have 2 laptops of this particular model with exact same fault-missing vcc gfx voltage. 2nd one is Uma, so likely not a graphics issue with the first one as well.
        Bit urgent help needed,if possible. I know we all are located across the globe with different time zone and all are busy but still request advice asap.
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          Help please guys
          • piernov
            • Jan 2016
            • 4439
            • France
            No idea, do you have a POST diagnostic card? Or if you have an oscilloscope, check for any activity on the BIOS ROM CS# pin. Also make sure that you have all the other CPU voltages (+1.05V_VTT, +1.8V, +1.5V_CPU, +VCCSA I think).
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              +1.05v VTT/1.8V/1.5V/VCCSA/0.60V/.075V/0.90V PRESENT. I dont have an oscilloscope to check.
              • mcplslg123
                • Jun 2015
                • 7262
                • india
                Thanks to all of you specially Piernov for support. I have solved the problem of missing +vcc_gfx voltage on Pl37. Solution is attached as screenshot. PR284 Bad.
                • piernov
                  • Jan 2016
                  • 4439
                  • France
                  Ok nice to see that you fixed it, I was on the wrong track… Still surprised that this resistor can die, thanks for the info.
                  • mcplslg123
                    • Jun 2015
                    • 7262
                    • india
                    I too didnt doubted it and thats why perhaps wasted so much time to fix it.
                    • afrojuju1
                      • Sep 2018
                      • nigeria
                      hello sir
                      plz were is d resistor location in my daor62mb6e1 thax
                      • fixfixit
                        • Jun 2010
                        • 14
                        • Sri Lanka
                        Thank you, it's a very useful tip!
                        • ktmmotocross
                          Boardkiller
                          • Feb 2014
                          • 3627
                          • slovakia
                          how did u find that fault?
                          • Lucifer87
                            rx 5700 pulse Schematic & Boardview request 1.8 missing sometimes present
                            by Lucifer87
                            Hi, I need the schematic and boardview of a Radeon RX 5700 Pulse, sometimes it turns on, sometimes it doesn't... I checked when it doesn't turn on, the enable signal is missing on pin 15 EN2 3v to power 1.8v... the problem is that when it works I can't test it since the signal is present... I would like to check the signal paths but I would need the diagram and the boardview thanks​...
                            12-15-2024, 12:29 PM
                          • Kooopa
                            Acer Nitro 5 EC_RSMRST# present, Missing SLP_S5#!!!
                            by Kooopa
                            Hi! I'm diagnosing my Nitro 5 AN515-43 Mobo: FH50Q LA-J621P. I left it on sleep mode but when I came back It won't turn on. Power LED would turn on for a few seconds then off. no fan spin nor keyboard backlight.
                            So I tried the usual procedures first, power cycling and bios reset but non did the trick so I decided to delve deeper.
                            Nothing strikes as red flags aside from the dust. there's no history of any liquid being poured at it since I bought the thing, I've been real careful. Anyways.
                            I checked the usual rails +5VALW +3VALW even the 1.8VALW and 0.9VALW...
                            09-06-2024, 11:38 AM
                          • Prott
                            Surface 7 - missing S3 sleep signal, S4 present but weird
                            by Prott
                            Hey fellow Badcappers
                            I am troubleshooting Surface 7 board (rev 1.0) which was working great until it experienced a short circuit due to a bad screen.
                            Now it's missing SLP_S3 signal. Everything in the power on sequence works properly up until that signal.
                            - The resistance to ground on the SLP_S3 line is >50 kOhms.
                            - No shorts on any powerrails that I can find.
                            - I get a proper clock signal on the RTC crystal (XTAL_2P) once the Surface gets power.
                            - SLP_S4 is, suprisingly, present, but it looks very weird (jump up to 2 V for about...
                            07-08-2023, 04:54 PM
                          • jagg
                            Hp pavillion x360 15-CR0087CL BOARD: LEIA_15 KBL UMA 17881-1B missing component
                            by jagg
                            Hello friends, I have this laptop which would not turn on, I detected that the 3v and 5v source circuits were damaged and a 6 pin circuit in short, which I suppose are diodes, I'm not sure since there is no diagram, I removed this circuit and the sources and there is no longer a short, the new 3v and 5v sources were installed and the laptop now works, the problem is that I don't know what this 6-pin circuit is, I think it has to do with the battery, since the operating system does not detect the battery, I measured the IC pins and they go to these pins of the battery connector, does anyone know...
                            04-23-2025, 12:48 PM
                          • saronno
                            1050ti asus cerberous: 1.8v present, 1.8v pgood missing ..
                            by saronno
                            I have this weird case where 1.8v is presente but 1.8v pgood is missing preventing the card to post.
                            The card sometimes post, in particular when mb and gpu are cold e without voltage for long time. If it post, then no problem, it loads the drivers and everything works fine.
                            the chip who provide 1.8v is an nb671lb.
                            have you ever had an issue like that on a 1050ti or any other pascal gpu?
                            TIA
                            05-07-2023, 05:15 AM
