DELL 3521 La-9104P problem
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Model : Dell Inspiron 3521
    Motherboard : La-9104p Rev 1.0
    Problem: Laptop boots fine with battery. In off condition ,if you plug in charger,Charging indicator is on and it does charge battery. Now, When the laptop is switched only on ac power, It doesnt boots, fan spins continiously and there is no vcc core. But if i switch on battery only,display comes fine and if i connect adapter now(While the laptop is on with display with battery power only), there is slight blink on the screen and display goes off but backlight remains on.
    Where should i look for??
    Ps: It uses Bq24747 as charging ic and not ISL
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: DELL 3521 La-9104P problem
    I'm using Dell 90W Original adapter(100% tested ok) and my battery is also tested fine. Tried with a dell 65w Adapter also.
    • mcplslg123
      • Jun 2015
      • 7262
      • india
      Problem resolved
      • ivmilicevic
        • Aug 2017
        • 14
        • Bosnia and Herzegovina
        How did you resolve problem? It's useful lo leave explanation, so that next person that searches for this knows what to look for
        • mcplslg123
          • Jun 2015
          • 7262
          • india
          here is how:
          +1.05v Line gets shorted when ac adapter plugged in-no vcc + coils near pch drops to 0v. On further probing ,found Pu500(Tps51212) is faulty.
          Replaced with Richtek alternative with marking 88. Problem solved.
          We'all are sharing knowledge with each other, so i dont have any issues sharing
          • SDNarcia
            Dell 15R-5521 keyboard problem (KBC?)
            by SDNarcia
            Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
            As additional information,...
            07-20-2024, 10:47 PM
          • jasonbay13
            Dell Inspiron 15-3521 ~ LA-9104P ~ No Power - corroded board with pics of damage and some voltages
            by jasonbay13
            it was working yesterday, i opened it up and saw this mess. boardview and schematic uploaded for convenience.
            PU200
            pin 17 vreg5 = 0v ~ solder joint was corroded and flicked right off with my probe, was able to get clean and reflow, rest look fine.
            pin 8 vreg3 = 0v
            pin 13 en = .2v
            pin 1,6 entrip1,2 = 0v
            b+ and b++ = 19.5v
            +5valw = 0v & 25+ohm to ground
            +3valwp = 0v & 25+ohm to ground
            i cleaned the board up just a little and can get more pics.​
            where should i be looking? thx...
            09-25-2025, 10:54 PM
          • Achille15
            Dell N5110 problem
            by Achille15
            so, I have this laptop Dell Inspiron N5110 with a heating problem on both CPU (I7-2680qm) and GPU (GT 525m), I tried many solutions, like changing thermal paste every month, using thermal pads on CPU and GPU, even using thermal pads on CPU nearby coils; but nothing worked, just minutes after booting the laptop shuts itself down so I thought it might be a short problem, so I decided to check what's going on, so I went online and some tutorial (general one) said to check inductors in order to find the shorted circuit, after checking (CPU removed), I found the culprit to be...
            03-29-2025, 04:41 PM
          • masoksian
            Dell latitude e7470 not turn on .power buton on off and Run Power problem
            by masoksian
            I am dealing with the problem of turning on and off my Dell e7470 notebook.
            The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
            The system does not turn on, there is no post.
            I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
            The problem continues in the same way.
            I tried to turn on the Fn key, nothing came to the screen....
            02-15-2025, 12:08 PM
          • MahmoudNasser
            Dell 7480 problem with freezing during the Windows loading process
            by MahmoudNasser
            Hello everyone, I wish you a happy day.
            I have a Dell Latitude 7480 laptop that has a problem with freezing during the Windows loading process. If it manages to boot up, it becomes very slow and doesn't load anything from the desktop.
            Device Data
            Model Dell Latitude 7480
            CPU:i7-7600U
            SN:7T58PL2
            MP PartNumper:CAZ20 LA-E131P Rev:1.0 A00
            Bios Chips:W25Q128BV
            The attempts that have been made to solve the problem have not yielded any results.
            1. Changing the M.2 and M.2 Nvme hard drives.
            2. Trying...
            07-09-2023, 05:04 AM
