hp pavilion g6 da0r33mb6f1 rev:f starting randomly
  • xfce
    • Aug 2017
    • 18
    • Bulgaria
    Hello people,
    i have issue with my laptop, which i can`t repair alone. Problem is : laptop will not start, led light on the dc port is on when is connected to the adapter , after pressing the start button nothing goes on, no fan spinning , no lights coming on (except power port , which is always on). Sometimes (randomly) laptop will start just like that. After that i can use it as much as i want, i can switch it off and on , no problems. if i leave it for awhile off , then same issue, wont start again. I have it already dissembled , so at the moment i`m testing motherboard + lcd + power button + ram. From what i can check with the multimeter so far i can get 19.4v after the power port (picture 1), then at the start button i can get on the first 2 pins 3.33 but nothing on the rest of them. I`m not really sure if i do the measure as it should be done, so if you have patience to explain me how and from where i should start checking components on the motherboard i will appreciate any help, thank you in advance
  • sourcebf
    • Jul 2016
    • 431
    • N/A
    Re: hp pavilion g6 da0r33mb6f1 rev:f starting randomly
    look at the board for any corrosion of legs of any IC..........
    • xfce
      • Aug 2017
      • 18
      • Bulgaria
      only thing i could find that i don`t like it is this picture, its HDMI port
      • sourcebf
        • Jul 2016
        • 431
        • N/A
        clean it properly....it is just dirt but can be the source of your problem..
        • xfce
          • Aug 2017
          • 18
          • Bulgaria
          cleaning didn't help, any other suggests ?
          • dellxps15
            • Feb 2014
            • 1588
            • italy
            wich chip northbridge and southbridge it has ? many notebook have intel nb chip failure or amd southbridge problem.
            • Th3_uN1Qu3
              Believe in
              • Jul 2010
              • 6031
              • Romania
              I don't think this is southbridge or PCH problem, more likely to have something to do with EC/KBC, but most likely some liquid damage, could be resistors or an intermittent solder connection. Got a schematic for the board?
              A working TV? How boring!
              • xfce
                • Aug 2017
                • 18
                • Bulgaria
                thank you for your help. yes i do have the schematic but i dont know how to read it or what to look for. What i have found so far is that under the keyboard and little on the CD/DVD have a sticky black dirtiness , could be a coffe or cola. Interested is i cannot find anything burn on the motherboard(except the picture ive attached near the HDMI), i got microscope so i`ve check it well.
                • fester
                  • May 2017
                  • 158
                  • Slovakia
                  reflash bios,it is eeprom memory and they dont like abuse(liquid) on its legs when reading and writing.also meassure pgood signals on KBC.but if you cannot read schematic and everything looks ok under microscope,throw it to the trash or find someone who repair it for you.
                  • Chieftain
                    • May 2016
                    • 72
                    • Greece
                    1. replace internal battery
                    2. check for cold "solds" in every 3v mosfets
                    • piernov
                      • Jan 2016
                      • 4435
                      • France
                      I've also got a Quanta R33 which sometimes acts up. Can't reproduce the problem right now, but not long ago it wouldn't boot on some occasions, staying on a black screen (with backlight), or freezing on the "Entering BIOS" (or something like that) message when trying to enter BIOS setup.
                      I noticed that the battery could cause issues. Mine is dead and sometimes the laptop will shutdown right after power up when the battery is inserted.
                      My issue is a bit different but I was wondering if it could be that big electrolytic cap right after the DCIN connector?
                      PS: I already tried to flash the BIOS. I didn't try to replace the BIOS IC though.
                      • Danidasanic
                        • Jan 2019
                        • portugal
                        Originally posted by xfce
                        Hello people,
                        Mine had the same symptoms ...after some hours spent on it testing everything (and after spending 150€ on a new MB..) I tried to disable the option to suspend the pc with the cover down..EUREKA! the hall effect sensor (aka lid sensor) was the culprit . I then desoldered the in and output , its working like a charm
