macbook pro 2008 - 2009 power alternative
  • magnetepazzo
    • Feb 2017
    • 85
    • italy
    Hi guis I have a problem with this macbook pro, when push button and power on the display are black and no sound, after try to repower the mac power regular but any time still on charge operating system.
    Suggestion ?
  • SarcasticOP
    General question about MacBook power rails for repair.
    by SarcasticOP
    I am looking at an A2337 and found this for the order of power rails and what they do. Can this be confirmed before I dive into hunting down power rails that do not exist or are not neccisary?
    • PPBUS_G3H (12.6V-12.8V)
      • This is the main power rail that supplies power to the entire system. Check this rail first, as it must be present for other power rails to work.
    • PP3V42_G3H (3.42V)
      • This power rail is derived from PPBUS_G3H and is used to power the SMC (System Management Controller) and other essential circuits. It should be present if PPBUS_G3H is working correctly.
    • PPVRTC_G3H (3.3V)
      • This
    12-12-2024, 05:50 PM
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
  • PantherDave
    by PantherDave
    Hi all!
    05-29-2024, 02:01 PM
  • GLISIT
    by GLISIT
    01-16-2025, 02:29 PM
  • bcstedt
    LG 42LB5D, 42LB5DF-UL, 2008-01, Power On Issue, Replaced PS Caps
    by bcstedt
    LG 42LB5D (42LB5DF-UL) from 2008-01, unit is in good shape and no obvious heat damage or cracked solder on the boards.
    Problem:
    On first power-up the power LED flashes green about 18x and then stays solid. No backlight or image is present. Click power button, wait 10s for a click and the LED turns red. Wait 1-2s and hit power again and maybe it'll power up fully after 6 green flashes. If it doesn't light up on the sixth flash then the cycle repeats.
    It seems that if the mainboard power is left on for a few minutes (solid green power, no backlight, no image)...
    01-18-2024, 01:03 PM
