i have lenovo B570, when shutdown in windows it shutdown okay, but the power key light stays ON and FAN still spinning untill battery run out.... how to solve this
Lenovo B570 power off issue
by GLISITHi all,
A few weeks ago I was using the laptop (on battery power) for a Zoom meeting. The battery was running very low (long meeting) but I wasn't worried about... -
by claws77hi guys, my motherboard will not start no matter what
when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
but rest nothing happens no sign of life.
this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
but now nothing happens no matter how much i wait/ charge/ press and hold power button.
i have no knowledge of motherboards ....10-20-2024, 02:48 PM -
by SuperJamesThis one's a weird one, and still unsolved despite it having gone back to Dell once.
Specs
i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
Backstory
I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...10-23-2023, 04:09 PM -
by kalilinux25Hi good day I have a issue of this motherboard laptop, if doing a cmos reset the the motherboard ( discharge the current inside the board) it will power on and if you shutdown
the laptop it wont power , it will shows led light for a second then shutdown.
Tried clean Me bios smae issue
tried to bypass thermal protection ( remove RB7 and RB1 and jumper each pad of the DB1 )
ive check the motherboard for corrion but no avail
Hope someone can guide which part of the board should I focus to narrow down the issue
FH5AT LA-K092P REV 2... -
by justice171I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:- Verified that all critical voltages are present:
- 3.3V and 5V are always present if DC is plugged.
- 1.8V on the BIOS chip is present.
- Checked the power button functionality:
- When pressed, the voltage drops to 0V, indicating the button is functional.
- Inspected the flex cable connecting the USB, audio, and power button to JUB1:
- Confirmed connectivity is intact, ruling out issues
11-26-2024, 12:39 AM - Verified that all critical voltages are present:
- Loading...
