Asus X550LDV only turns On without the CMOS Battery
  • passete
    Living=Sharing
    • Jun 2015
    • 487
    • France
    As the tittle says, this laptop, won't turn ON (When i press the ON switch).
    It charges the battery, and only way to put it working, is by removing the battery and the CMOS battery, like this when i connect the psu, the laptop works Normally.
    Any Tips Guys ?
    PS: i have updated the bios and replaced the Switch On Pcb, No change
  • passete
    Living=Sharing
    • Jun 2015
    • 487
    • France
    Re: Asus X550LDV only turns On without the CMOS Battery
    Found the culprit, replaced the ffc cable between the mobo and the On/Off pcb.
    I've checked before with microscope the actual cable, but no signs of problems ...
    Anyway, we learn everyday
    • questore
      XPS 13 9370 CMOS battery voltage always low
      by questore
      Hi Everyone,
      I have brought you a mistery item
      This laptop have come with some strange faults.
      1. CMOS battery was flat 0v
      Symptoms:
      - After using the laptop and shutting down and removing the AC adapter for at least 1 minute, the laptop never turned on until EC reset (either shorting RTC or removing battery and long pressing power button)
      Amp drawing was stuck at 0.005 milliamps.
      - Laptop cannot really be turned off because it autostarts about 5 sec-1 or 2 minute. (lid sw is not the problem)
      After inverstigation RTCD1 diode had a low value...
      09-30-2025, 05:47 AM
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
    • dhenion
      Asus VivoBook F510UA-AH51 won't run on battery after motherboard replacement
      by dhenion
      I'm working on my sister's laptop: Asus VivoBook F510UA-AH51 - The motherboard died so I replaced it.
      The original board was:
      ASUS X510UNR REV 3.0 A
      The replacement board is:
      ASUS X510UNR REV 3.0 B (identical except B vs A - I couldn't find an A board anywhere. Visually they are identical.)
      It boots right up on the replaced motherboard and everything works fine on the new motherboard - but it won't run off battery. When I disconnect the charger it immediately dies. When I plug it back in and reboot the system - it still shows the battery at...
      01-30-2024, 01:45 PM
    • rob777
      Asus TUF won’t run off battery
      by rob777
      I have an Asus TUF machine that doesn't run off battery. Runs off charger ok, shows orange battery charging light and shows battery is at 96%. Battery voltage is less than 0.5v though. It had a short on the 20v rail from a dead cap. Pic attached. Removed cap and replaced a dc in mosfet. Machine now powers and runs fine.
      I have also replaced all 3 battery mosfets with no change. The 1st battery mosfet has 20v going in. Pic attached.
      Does it sound like a battery ic problem, it has bq2470. Not sure if I should replace that as well at this stage as I'd need to order one.
      Thanks....
      05-27-2025, 07:07 PM
    • Iherduleikgemz
      Asus FX505DY - Battery not charging - BQ24780S
      by Iherduleikgemz
      Hello everyone
      I have been working on this laptop mentioned in the title, it initially had a shorted capacitor. After I replaced it, the thing started working again, but there is still another problem. The laptop was running off a charger, the battery was reporting 96% charge... but when I unplugged the charger, the laptop died. I've measured the battery voltage - 0V. I think it is locked. (Screenshot from batterymon, below).
      I've ordered a new 3rd-party battery, but I think there's something wrong with it too - the laptop boots, but the battery isn't charging. Also,...
      01-13-2025, 03:54 PM
