VAR00 LA-9201P short to ground
  • bjhawfam
    • 144
    I initially had a short to ground ,, AND,, the power cord ( AC adapter ) light would turn off. I found the short on mosfet pq607 and replaced the bad N-channel mosfet. Now the charger stays on and this enables me a better chance to test with actual voltage. The next issue is no power, I get voltage in 20 volts,, and the power board receives 5 volts. Chips U3 and U4 are NOT getting power. Not sure where they pull the voltage from... I included the schematic, any help is appreciated.
  • bjhawfam
    • 144
    Re: VAR00 LA-9201P short to ground
    I took voltage readings at JLED1 20 PIN connection to the power board.
    pin 1 ,,, 0v
    pin 2 ,,, 5v
    pin 3 ,,, 5v
    pin 4 ,,, 0v
    pin 5 ,,, 0v
    pin 6 ,,, 0v
    pin 7 ,,, 3v
    pin 8 ,,, 3v
    pins 9, 10 , 11 ,,,, 0v
    pin 12 ,,, 3v
    pins 13, 14, 15 ,,, 5v
    pins 16, 17, 18, 19, 20 ,,, 0v
    • bjhawfam
      • 144
      Update,,, found another short on the power board resistor R25,,, now I have power to the led lights, and, still not turning on .... Will continue my quest.
      • bjhawfam
        • 144
        UPDATE AGAIN,,, found the chip q9 on the powerboard ul indicator getting very hot. Does anyone know by chance what this chip is?
        • bjhawfam
          • 144
          q9 still gets very hot right when laptop is plugged in... replaced the chip several times and no change.... not sure why its heating up so fast..
          • cpt.charlie
            • Sep 2013
            • 270
            • Spain
            Q9 in the diagram is a SSM3K7002F n-ch mosfet in sot 23 package, related to HDD activity indicator, in theory you can remove it and the board should work unless it has more components damaged.
            • bjhawfam
              • 144
              Hello,,
              Thanks I addressed this problem, actually bought a new board. The main reason I bought a new board was the ribbon cable was damaged ( the ends frayed and missing or touching).. To minimize time and headache I replaced the board and cable.. Now the heat issue is resolved.. Thanks again.
