hp nx6110 problem on hub USB
  • karim011
    • Nov 2016
    • 118
    • Morocco
    Hi Guys. i have hp nx6110 problem on hub USB. When connecting any Device USB error message
  • karim011
    • Nov 2016
    • 118
    • Morocco
    Re: hp nx6110 problem on hub USB
    pls solution.
    • jiroy
      • Jun 2016
      • 2416
      • Lebanon
      Check this page and the first three solutions:
      https://answers.microsoft.com/en-us/...a-c0e724e83e04
      • khaahk
        • Dec 2013
        • 751
        • Estonia
        Most likely you need to resolder or change southbridge. If you have the means and skill to do bga soldering.
        • theone111
          by theone111
          3. Problem: TV shuts down
          07-22-2024, 10:36 AM
        • Gibon378
          Problem with stopping audio and video for no reason
          by Gibon378
          PC Specs:
          • CPU: Ryzen 5 1600
          • GPU: GTX 1080 Palit JetStream
          • MOBO: ASRock ab350 PRO4
          • RAM: Crucial Ballistix Sport 2x8GB 3000MHz (XMP 2.0)
          • PSU: XFX 650W (don't remember what model)
          • OS SSD: ADATA SP920
          • OS: Windows 10 21H2
          Problem description:
          Hi. I have a problem that has been going on for some time (2-3 years). It's hard to explain what it really is. Sometimes, my computer stops playing music, stops videos (starts buffering on youtube), there is no sound in games and when I minimize the game window and return to the game there is a black screen with window borders...
          11-19-2022, 09:41 AM
        • zaler808
          Macbook Pro 15" Late 2013 A1398 Turn off randomly but after workload it shows black screen with fans spinning
          by zaler808
          Hi guys, this my first post but i want to be brief about it, i recently got a MBP L2013, the problem was that after some use the macbook shutted down randomly, at first i suspected to be the battery, and after connecting it with the charger i noticed that i didn´t shut, but after an hour or so it shutdown, after that i started searching a solution to my problem, but my brother tried to help me to find the problem and it that process to replicate the problem he reproduced a 4k video in multiple tabs and not much time after the macbook shutdown to never power again, what i noticed was that the...
          05-23-2024, 05:17 PM
        • SDNarcia
          Dell 15R-5521 keyboard problem (KBC?)
          by SDNarcia
          Hello, I have a Dell 15R-5521, with the problem that the Ctrl, Alt, Shitf and Num Lock keys do not work, I tested the keyboard with a keyboard tester and it is functional, I also got another new keyboard and the computer has the same problem with the same keys. Check continuity between the ZIF connector from the keyboard to the KBC and all pins are correct. I cleaned the ZIF connector and the KBC and I still have the same problem. I reinstalled windows just in case, and it didn't work. I updated the BIOS to the latest version A16 and there were no changes.
          As additional information,...
          07-20-2024, 10:47 PM
        • funyy
          LG OLED55B8PLA problem
          by funyy
          Hey there,
          So I got a problem with my LG OLED TV (OLED55B8PLA).
          the problem is that the tv won‘t power on some times, the led stays red and won‘t even blink, just solid red when I try to turn it on. USB devices connected won‘t light up. 1/4 of the screen (left side) shows some green „clouds“ that are getting brighter everytime I turn the tv on and after some tries the tv finally turns on. Sometimes it takes 10 tries and some times 100 or even more tries.
          When the tv is on, everything works fine, hdmi outputs, usb inputs, wifi, bluetooth, etc is working...
          04-30-2022, 07:51 AM
