Dell 5010 3 Beeps - Auto power when plugged in
  • s.m.hosein
    • Jun 2015
    • 23
    • esf
    inspiron 5010 when plugged the adaptor power on automatically and after few sec start 3 beeps
    no display .... (cmos battery have 3.3 )
  • raajkumar
    • Mar 2015
    • 354
    • Srilanka
    Re: Dell 5010 3 Beeps - Auto power when plugged in
    For 3 Beeps shows following problems
    *. chipset Error (North and South bridge error, DMA/IMR/Timer error)
    *. Time-Of-Day Clock test failure
    *. Gate A20 failure
    *. Super I/O chip failure
    *. Keyboard controller test failure
    Check it
    • s.m.hosein
      • Jun 2015
      • 23
      • esf
      well i know that but i was hoping maybe someone have the same issue or help to find the problem
      • s.m.hosein
        • Jun 2015
        • 23
        • esf
        any idea guys ???
        i got another with same terms!
        this time 7 beeps but still when plugged the adapter auto turn on!
        • caspian
          • Oct 2015
          • 1591
          • Laptop
          check the SIO pins to discover which one is not correct.
          • 580shahzad
            • Jan 2012
            • 61
            • PAKISTAN
            Dell 3542 give 3 beep i programme bios laptop work fine
            • s.m.hosein
              • Jun 2015
              • 23
              • esf
              bios have been programed and i change the i/o.... still the same
              • tharwat725
                • Dec 2017
                • alex
                thank you
                • abbas_govani
                  • Jul 2013
                  • 89
                  • India
                  hello brother i had same issue with dell 5010.
                  after checking little bit on board. i detect rt8205b is heating little bit.
                  so i replaced it with new one. and luckily it worked.
                  • shouri
                    Dell latitude e5490 auto restart
                    by shouri
                    Hi guys, can someone help me?
                    I have an issue with laptop dell latitude e5490 that auto restart when arrive at certain point in loading windows.
                    Board model is dm70 la-f401p rev:1.0 2017-09-20.
                    At first, the issue is sometime ssd sata 2.5 not detected. i already try another cable, at certain point, it ok using old cable (i mean sata cable here).
                    After a few days test, is seems ok.
                    Days later, another issue come, that is auto restart when certain point in loading windows. i already test another ssd, another ram, another sata ribbon, still same....
                    12-10-2024, 09:27 PM
                  • Bowline
                    by Bowline
                    06-11-2025, 10:13 AM
                  • Thomasraud
                    Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
                    by Thomasraud
                    i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
                    QUOTED
                    -It works on charger (without battery connected-only charger)
                    -It works on battery (without charger connected-only battery)
                    -& it also works when plugged in battery & charger, but it's not charging the battery
                    //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
                    and..
                    QUOTE
                    The IC cannot maintain the input current level
                    06-28-2022, 06:47 PM
                  • cygron
                    Dell Latitude 3440 2 Beeps Problem
                    by cygron
                    Model: Dell Latitude 3440
                    Board id: DL340-HSW MB 13221-1 Rev: A00
                    Laptop produce 2 beeps. RAM is ok (replace and test). And i think RAM Slot is also ok. Board have 2 RAM Slots. All coils have voltage expect PL5101. DRAMRST has only 0.12V. BIOS flashing can't solve the problem. Need help.
                    PL4503 - 3.3V
                    PL4101 - 5V
                    PL4902 - 1.35V
                    PL4801 - 1V
                    PL4701 - 1.7V
                    PL4401 - 17V
                    PL5101 - 0V
                    PU5102 pins -
                    Pin 1 - not stable ( 0.5, 1.3, 5.9 etc ... )
                    Pin 2, 4 - 0V
                    Pin 3 - 0.95V
                    Pin 5 - 2.87V
                    Pin 6 -...
                    04-20-2025, 03:46 AM
                  • master3112
                    by master3112
                    07-29-2025, 01:55 PM
