Hp Dv6 with power issue
  • emmanuelbill1988
    • Mar 2017
    • 100
    • ghana
    A customer brought this Hp dv6 which is dead,after making small check on mobo,i found out there is no 3.3v under power switch can anyone help me with schematic please?tnx in advance
    mobo number is DA0UT1MB6E0 REV:E
  • jiroy
    • Jun 2016
    • 2416
    • Lebanon
    Re: Hp Dv6 with power issue
    Hp Dv6 DA0UT1MB6E0 REV:E schema :
    • jasko_jacker
      • Oct 2014
      • 1140
      • italy
      check if this schematic correspond with your hardware
      • emmanuelbill1988
        • Mar 2017
        • 100
        • ghana
        Tnx very much friends,most grateful
        • emmanuelbill1988
          • Mar 2017
          • 100
          • ghana
          those once does not correspond with my mobo,pls can someone help?will be very grateful if someone will share
          • gcomputers
            • Apr 2013
            • 509
            • Albania
            try this
            • jiroy
              • Jun 2016
              • 2416
              • Lebanon
              ...Or this one :
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3628
                • slovakia
                for basic check u dont need schematic.
                just check all coils for voltage
                • GLISIT
                  by GLISIT
                  01-16-2025, 02:29 PM
                • justice171
                  Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
                  by justice171
                  I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
                  Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
                  1. Verified that all critical voltages are present:
                    • 3.3V and 5V are always present if DC is plugged.
                    • 1.8V on the BIOS chip is present.
                  2. Checked the power button functionality:
                    • When pressed, the voltage drops to 0V, indicating the button is functional.
                  3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
                    • Confirmed connectivity is intact, ruling out issues
                  11-26-2024, 12:39 AM
                • claws77
                  lenovo flex 5 14itl05 power sequence issue
                  by claws77
                  hi guys, my motherboard will not start no matter what
                  when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
                  but rest nothing happens no sign of life.
                  this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
                  with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
                  but now nothing happens no matter how much i wait/ charge/ press and hold power button.
                  i have no knowledge of motherboards ....
                  10-20-2024, 02:48 PM
                • yaya3gmax
                  Laptop Power Issue – Works on Battery, Fails on Adapter Load
                  by yaya3gmax
                  Dell laptop (E7440, uses the notorious CD3301B power controller + MEC5075 EC + BQ24715 charger IC)
                  Symptoms:
                  • Laptop works normally on a pre-charged battery.
                  • Battery does not charge when adapter is connected.
                  • Without battery:
                    • Laptop powers on from DC adapter, passes CPU/RAM init checks, then cuts DC power abruptly.(seems to shutdown one of the mosfets in the charger path). Then the loop continues indefinitely
                    • Speakers “pop” when power cut occurs indicating harsh sutdown.
                    • If RAM is removed, the system shows RAM missing blink error code indefinitely without cutting DC power
                  08-21-2025, 07:16 AM
                • SuperJames
                  Dell G3 17 3779 Weird power cycling and shutdown/restart issue
                  by SuperJames
                  This one's a weird one, and still unsolved despite it having gone back to Dell once.
                  Specs
                  i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
                  Backstory
                  I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
                  10-23-2023, 04:09 PM
