Hp Dv6 with power issue
  • emmanuelbill1988
    • Mar 2017
    • 100
    • ghana
    A customer brought this Hp dv6 which is dead,after making small check on mobo,i found out there is no 3.3v under power switch can anyone help me with schematic please?tnx in advance
    mobo number is DA0UT1MB6E0 REV:E
  • jiroy
    • Jun 2016
    • 2416
    • Lebanon
    Re: Hp Dv6 with power issue
    Hp Dv6 DA0UT1MB6E0 REV:E schema :
    • jasko_jacker
      • Oct 2014
      • 1137
      • italy
      check if this schematic correspond with your hardware
      • emmanuelbill1988
        • Mar 2017
        • 100
        • ghana
        Tnx very much friends,most grateful
        • emmanuelbill1988
          • Mar 2017
          • 100
          • ghana
          those once does not correspond with my mobo,pls can someone help?will be very grateful if someone will share
          • gcomputers
            • Apr 2013
            • 509
            • Albania
            try this
            • jiroy
              • Jun 2016
              • 2416
              • Lebanon
              ...Or this one :
              • ktmmotocross
                Boardkiller
                • Feb 2014
                • 3592
                • slovakia
                for basic check u dont need schematic.
                just check all coils for voltage
                • GLISIT
                  by GLISIT
                  01-16-2025, 02:29 PM
                • justice171
                  Acer Spin 1 SP111-33 Power-On Issue (Troubleshooting Assistance)
                  by justice171
                  I am seeking guidance on an Acer Spin 1 SP111-33 that does not turn on when pressing the power button.
                  Below are the observations and troubleshooting steps I have taken so far: Observations and Tests:
                  1. Verified that all critical voltages are present:
                    • 3.3V and 5V are always present if DC is plugged.
                    • 1.8V on the BIOS chip is present.
                  2. Checked the power button functionality:
                    • When pressed, the voltage drops to 0V, indicating the button is functional.
                  3. Inspected the flex cable connecting the USB, audio, and power button to JUB1:
                    • Confirmed connectivity is intact, ruling out issues
                  11-26-2024, 12:39 AM
                • claws77
                  lenovo flex 5 14itl05 power sequence issue
                  by claws77
                  hi guys, my motherboard will not start no matter what
                  when connected to ac power, the battery does get charge, led indicator glows red when discharged and turns white as it is fully charged.
                  but rest nothing happens no sign of life.
                  this laptop has one preexisting usbc power issue - so i use DCIN jack for charging my laptop.
                  with this issue my laptop was unable to power ON only sometimes i just had to wait some time.
                  but now nothing happens no matter how much i wait/ charge/ press and hold power button.
                  i have no knowledge of motherboards ....
                  10-20-2024, 02:48 PM
                • SuperJames
                  Dell G3 17 3779 Weird power cycling and shutdown/restart issue
                  by SuperJames
                  This one's a weird one, and still unsolved despite it having gone back to Dell once.
                  Specs
                  i7-8750H, GTX 1060 Max Q, 500GB SSD & Seagate 7mm 1TB HDD. 17.3 IPS screen. This has the fingerprint reader in the power button.
                  Backstory
                  I bought this from eBay, from a wallpapering shop. £650 in 2020 which was a good price considering it's a gaming laptop. Physically it's in perfect shape, apart from the hinge mounts on the palmrest failing in the time I've had it (I have a new palmrest for it). The usual thin plastic crap modern build quality!...
                  10-23-2023, 04:09 PM
                • Soulzink
                  Samsug washing machine. Power supply DC41-00189a board issue
                  by Soulzink
                  I am trying to fix a samsung washinmachine power supply main board.
                  I already replaced it with another one to fix the machine but i want to try understand the issue with the old board.
                  Therefore i hope to be able to get some help to explain what to check in order to troubleshoot.
                  The power supply board reference is the following: DC41-00189a
                  I have followed one thread (https://www.badcaps.net/forum/troubl...ingmachine-rel...
                  04-19-2025, 06:26 AM
