ic oz8119
  • NConstantinou
    • May 2017
    • 351
    • Cyprus
    ic oz8119
    I google to find pins layout for oz8119 but i couldn't find anything.
    Does anyone knows the pins layout for this ic!
    Thnks
    NConstantinou
  • JaroTech
    • Mar 2015
    • 351
    Re: ic oz8119
    Hi, the only information I found is this picture.
    • NConstantinou
      • May 2017
      • 351
      • Cyprus
      Re: ic oz8119
      that i found. i have a short on pin 12 of this ic and i was wondering if it is input or output.
      Pin states CSN
      • petehall347
        • Jan 2015
        • 4444
        Re: ic oz8119
        wonder what csn stands for ?
        • JaroTech
          • Mar 2015
          • 351
          Re: ic oz8119
          CSN is an input, inverting current sense pin, check the capacitor connected to this pin.
          • corrize
            Where to find a very small fpc connector 0.3mm between 2 pins ?
            by corrize
            Hello, I search this connector (oxydated).
            It's a fpc zif low profile connector. It come from camera sensor, it is very small : 0.3mm between 2 pins.
            I ordered 2 from Aliexpress called « 0.3mm pitch » but one was 0.5mm between 2 pins and the other 0.6mm. In fact « 0.3mm pitch » seams to be the pad width and not the distance between 2 pins.
            I can't find it. The other websites like mouser dont show the datasheet, and I can't check if it is 0.3mm between 2 pins ?
            Do you know how to find this connector please ? What is the exact name for find it ?
            08-06-2024, 05:25 PM
          • Alex7eagl
            Macbook A1708 / 820-00840-A / Help with find the IC pins
            by Alex7eagl
            Help me find the IC pins. My motherboard has a burnout in the place marked with a yellow square. I need to find out where these two contacts are connected. Since there is no boarview for this modification, I need help from more experienced technicians.
            IC PI3USB32324AXEAE​...
            10-08-2024, 10:07 AM
            by Vesko356
            08-11-2023, 03:27 AM
          • SS454
            vizio e650i-a2 backlight flashes then turns off
            by SS454
            vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
            panel: au optronics T650HVN05.4
            72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
            link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
            Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
            https://www.shopjimmy.com/vizio-56-0...-power-supply/
            Vizio 55.75J01.001G (91.75J10.004G) Main Board...
            08-20-2020, 03:57 PM
          • langbaobao
            DIY 3D-Printer WSON8 Pogo Pin Adapter
            by langbaobao
            Hi.
            I'm posting this here in part as a memo to self as well as to describe the procedure I used in case anyone else found it useful. I found a lot of the necessary information to make this work on this forum and I figured I would give something back. If this is not the appropriate place to post this, I don't mind it being deleted but I hope it can help other people.
            I got an admin password locked HP Elitebook 840 G5 recently that I wanted to unlock. I'm a relative newcomer to reprogramming and unlocking firmware. The only previous experience I had was unlocking a BIOS...
            01-08-2024, 05:58 PM
