G73SW component info
  • jasko_jacker
    • Oct 2014
    • 1137
    • italy
    I need to convert g73sw motherboard from 3d to I think do this I have to add some components , (only resistor and capacitor) near 2d connector.
    Unfortunally the boardview does not show component value.
    I'm looking for a photo of the area around the lcd connector or datasheet or someone can help me with components value
    thanks
    [MOD EDIT] Link to boardview - https://www.badcaps.net/forum/showthread.php?t=126077
  • jasko_jacker
    • Oct 2014
    • 1137
    • italy
    Re: G73SW component info
    After some changes, the 2D LCD goes on but without backlight. To enable
    I need to find two resistor value, R4529 and R4530.
    • meritosari
      • Oct 2010
      • 774
      • Indonesia
      if following schematic pegatron x750lb, only 0 ohm resistor, maybe try with 10k first for safety, if not work, downgrade it to 5k and so on till you get the backlight.
      How many value R4733? Maybe only need moving R4733 to R4529???
      My interpretation: pics
      Is it possible that both ICs are controlling at the same point?
      if Signal coming from ITE, R4530 unstuff.
      if from MXM then R4529 unstuff
      • jasko_jacker
        • Oct 2014
        • 1137
        • italy
        Probably 0 ohm according to g75vw boardview that use the same lcd and not use any resistor to make the same connection.
        But R4733 is not in place, this is another via to connect LCD_VGA_PWM signal
        my schema has an error
        This is my doubt:
        I don't know if the signal PWM came from MXM or ITE and if I put in place both R4530 and R4529 ?
        • meritosari
          • Oct 2010
          • 774
          • Indonesia
          G53SX signal coming direct from MXM with 0 ohm, so maybe unstuff R4529. Only need put R4530.
          G73vw, same logic with asus N73SV, so different I think.
          • highpulse
            i hate HP
            • May 2013
            • 1488
            • portugal
            R4530 is a 0 ohm resistor
            r4529 doesn't mention value on boardview , cheking sequence , it show you can add something near 10 ohm or even less
            • jasko_jacker
              • Oct 2014
              • 1137
              • italy
              Finally this is the G73S LCD POWER CIRCUIT modified to use 2D 40 pin LCD instead a 50 Pin 3D LCD.
              1 - LCD_PWM:
              3D_LCD receive PWM through R4734 0_Ohm ADD R4529 0_Ohm.
              This pwm signal comes from VGA_CARD, there is an option to get it from ITE placing R4733 and
              removing R4734 ??
              2 - +3VS_LCD:
              Add L4501
              3 - LCD_BL_EN:
              LCD receive enable signal from R4736 and a res. partition R4735-R4737 but i I think is possible
              to get this signal removing R4736 and add R2445
              • Pak Sonny Komputer
                • Sep 2023
                • Indonesia
                sorry for my bad english, can you explain what you have done in detail, because I have tried and the result only displays red green blue white black repeatedly on the screen with the screen light off
                • Sus256
                  HISENSE 65E7KQ PRO - no boot
                  by Sus256
                  Hi all!
                  HISENSE 65E7KQ PRO
                  RSAG7.820.13512 - chassis
                  MT9618BAATAB - cpu
                  RSAG7.820.12059 - power
                  HD650Y3U77 - panel
                  KLM8G1GETF - emmc
                  The TV does not turn on, the standby indicator is on. All voltages are present.
                  Emms is dead. Not readable, not detected.
                  Replaced emmc.
                  But with another dump there is no launch
                  Terminal log
                  UART
                  AC_ON
                  RPMB key is not yet programmed
                  HASH1_VERSION=0x00000000 64bit
                  E-B
                  FDE enabled
                  layout pattern onebin by SAR7,0...
                  06-01-2025, 02:11 AM
                • jinu_j
                  by jinu_j
                  Hi
                  05-03-2025, 10:51 PM
                • mikey5791
                  Need help to replace burned resistor in 350w atx psu
                  by mikey5791
                  Hi to all forum members,
                  Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                  The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                  Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                  Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                  12-26-2024, 04:55 AM
                • MidnightRoller
                  Can a resistor lose resistance after hot air?
                  by MidnightRoller
                  I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                  I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                  02-02-2022, 11:46 PM
                • artvandalai
                  What resistor ohm will work better to repair this waterpik?
                  by artvandalai
                  The resistor on this waterpik blew. I changed it with the a similar spec 47ohm 2 watt yageo resistor but it still keeps blowing the resistor. Checking with the multimeter the motor, capacitor, diodes, and thermal fuse all checked normal. Will a higher ohm resistor work better? What ohm resistor will work better to repair this waterpik? This video is showing the repair with a 56 ohm resistor https://www.youtube.com/watch?v=_J7_rV7ui1Y
                  01-05-2025, 04:10 PM
