HP Pavilion DV7-1015eg Power issue
  • onlyprinzp
    • Mar 2017
    • 14
    Hallo everyone,
    I have a problem with my HP Pavilion DV7 1015eg. The main problem is that when I press the power on button all LEDs blink for a split second and nothing happens. The LED on the power jack turns off aswell! I need to take out the adapter and hold the power button for 5 seconds put it back in and the LED of the jack lights up again. If i press the power button same happens, all leds light up for a split sec and nothing. When I connect the battery the charging led lights up and after 3-5s it starts blinking in 1Hz infinitly.
    I took out the whole board from the case, took out cpu and ram too as well as fan heatsink and so on but still the same.
    Edit:
    I desoldered the PL702 due to the fact that it was shorting 0.0ohms on both sides. Found out the the one leading to "+NVVDDP" is short to ground. (Maybe it is supposed to I am noob sorry).
    I also took off PQ701, PQ702 and PQ703 in order to test those MOSFETs but all where in good condition (drain wasnt short with source or gate)
    In another post I found a similar problem and there the solution was a dry joint at PL3, took a look at it couldnt see any dry joint but resoldered it without any success.
    Can somebody help me please?
    I attached the schematics for my board: LA-4082P Rev: 1.0
    Cheers and thanks in advance!
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: HP Pavilion DV7-1015eg Power issue
    Check the "VGA Core power" caps on page 20, you may have a shorted GPU. Make sure the resistance is indeed lower than 1ohm. A GPU power line will show a low resistance (a few ohm) even in perfect working conditions.
    If you're lucky, it's only a shorted cap on this line. You'll need to inject voltage (less than 1V) on this line to find the faulty component. It'll be heating up.
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3593
      • slovakia
      offcourse bad GPU. whole 8XXX and 9XXX is bad. whan u have short, the GPU is burn. replace it
      • onlyprinzp
        • Mar 2017
        • 14
        Hey piernov,
        thank you for your reply. I am a bit noob, I put my multimeter on ohms autorange and put the sticks on each side. I tested it with C1098,C1099 and C1100 but it always says 0.0 like nothing.
        I then took my dc power supply, put it to 0.9V about 3.5A, desoldered C1108 and attached the + to the board, attached the - to gound. Very strange is that I get 0.014V only when I measure both wires with my multimeter?
        I really do not know whats happening?
        • onlyprinzp
          • Mar 2017
          • 14
          How did you come to this conclusion please I want to learn and understand. This is not 8xxx or 9xxx it is 1xxx series.
          Thank you
          • onlyprinzp
            • Mar 2017
            • 14
            *bump*
            • salmanzeiad
              • May 2016
              • 68
              • world
              plz i need bios for hp 455 g3
              • onlyprinzp
                • Mar 2017
                • 14
                OMG why don't you open a new thread yourself and spam in mine?!
                • salmanzeiad
                  • May 2016
                  • 68
                  • world
                  i`m new user>>>and can not create new post!
                  • salmanzeiad
                    • May 2016
                    • 68
                    • world
                    pic
                    • ktmmotocross
                      Boardkiller
                      • Feb 2014
                      • 3593
                      • slovakia
                      in your schematic is only NB9P-GS - 9600M GT,
                      or NB9M-GE - 9200M GS/Quadro NVS 150M
                      where u have 1XXX series?
                      • onlyprinzp
                        • Mar 2017
                        • 14
                        Oh okey sorry I thought you were talking about the HP Pavilion model number.
                        Can you maybe explain short how you know this ?
                        • ktmmotocross
                          Boardkiller
                          • Feb 2014
                          • 3593
                          • slovakia
                          many of it reballed/replaced
                            09-06-2024, 05:59 AM
                            HP Pavilion Power 580-187nz Pavilion Power i7-8700 Specification for Upgrade or Repair
                            This specification for the HP Pavilion Power 580-187nz can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-187nz boardview and Pavilion Power 580-187nz schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                            09-12-2024, 02:15 PM
                          • GLISIT
                            by GLISIT
                            01-16-2025, 02:29 PM
                            HP Pavilion Power 580-071na Pavilion Power i5-7400 Specification for Upgrade or Repair
                            This specification for the HP Pavilion Power 580-071na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Pavilion Power 580-071na boardview and Pavilion Power 580-071na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                            09-12-2024, 02:00 PM
                            HP Pavilion Power 15-cb094tx Notebook 15 Specification for Upgrade or Repair
                            This specification for the HP Pavilion Power 15-cb094tx Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Power 15-cb094tx boardview and Power 15-cb094tx schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                            09-06-2024, 05:54 AM
