logic board 820-2879
  • naitek
    • Feb 2016
    • Bahamas
    hello all,
    have following issue;
    u7500 shorted and was replaced as well as current limit resistors near
    u7000.
    board was having voltage fluctuations
    12.5 v - 0.3 volts and back up again.
    now, the fan starts , but no chime , no backlight.
    have ppvcore and mcp core as well as Frequency @ y2810
    any help would be great where to check next .thanks
  • pateldee@live.co.uk
    • Jul 2014
    Re: logic board 820-2879
    MCP89 dead
    • Pedro147
      • Sep 2016
      • 168
      Check resistance to GND of PP3V42_G3H. Anything less than 20 -30K ohms is generally dead MCP > one way trip to the bin sorry
      My YouTube channel - https://www.youtube.com/channel/UCiD...5d6OgizDqoi_SA
      • Tynan Dill
        by Tynan Dill
        Assuming...
        11-22-2024, 01:46 PM
      • m1ch43lzm
        by m1ch43lzm
        05-12-2025, 08:37 PM
      • ohren
        Upgrading a Samsung ue55nu7096u with logic board from an ue55ru7105k -- good idea?
        by ohren
        I hope this is the right forum to post in despite not technically being a repair, but still a question of swapping boards.
        I thought I'd explore the possibility to upgrade an existing working Samsung ue55nu7096u with the logic board (and power board if needed) of a newer model (ue55ru7105k) of the same size and appearance (and resolution). The reason being I'd like the extra inputs of that board including component in, an extra HDMI port and bluetooth. Its panel is broken so I have no use for the board otherwise.
        The models launched in 2018 and 2019 respectively....
        09-08-2023, 05:24 PM
      • Yanleb
        LG 60PK550 Logic Control Board EBR63450301
        by Yanleb
        Hi all, I just want to share the repair of my 60PK550-UA TV set.
        The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
        But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
        All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
        C57: 3.30V
        C61:...
        07-20-2023, 12:38 AM
      • korben_dallas
        Will I have a bricked logic board after reflow of the GPU v-core U8900 chip on my Mid-2012 15" Retina Macbook pro?
        by korben_dallas
        Hi everyone! I'm trying to fix my black screen / failed U8900 GPU v-core on my Mid-2012 Macbook Pro 15" Retinaby doing a rework/reflow of the chip (once I determine that's the real issue; but it likely is).
        I've been disabling the GPU in NVRAM for a few years... but it's just time for a better solution.
        I'm new to soldering but the only feasible way to fix this issue is to do something myself.
        MY QUESTION:
        I've been seeing some people (on this forum mostly) run into issues with the logic board needing a serial number or it being deactivated (?)...
        02-14-2024, 12:23 AM
