ASUS N56VM no power
  • piernov
    • Jan 2016
    • 4435
    • France
    Re: ASUS N56VM no power
    Low resistance to ground on CPU VCore is normal when the CPU is plugged in, especially on core i7 Ivy Bridge it can be 1 or 2 ohms only.
    On PU8100, +5VAO and +3VAO are the LDO outputs that are present as soon as the PU8100 receives power on its VIN pin 11 and the enable signal on its ENLDO pin 12 is high. This should be the case as soon as the system receives power (19V present after the DC in MOSFET).
    The +5VO and +3VO outputs are the buck regulator outputs. They each require their enable signal, ENTRIP1 pin 2 for +5VO and ENTRIP2 pin 4 for +3VO. This happens later in the power on sequence and requires the EC to send out the 3VSUS_ON/5VSUS_ON after receiving power from +3VA_EC and having its reset signal EC_RST# deasserted (going high).
    • GLISIT
      by GLISIT
      01-16-2025, 02:29 PM
    • Tynan Dill
      by Tynan Dill
      Assuming...
      11-22-2024, 01:46 PM
    • PantherDave
      by PantherDave
      Hi all!
      05-29-2024, 02:01 PM
    • ShadowAi
      ASUS TUF X570-PLUS doesn't power on: no VRM_EN signal.
      by ShadowAi
      Hello, I have an issue with the motherboard. Specifically, it doesn't power on, more precisely, the POST initialization doesn't occur.
      Let me start from the beginning, the motherboard suddenly stopped working one day. There are no beep signals from the speaker, and the debug LEDs are not lighting up. After inspecting it under a microscope and using thermal imaging, I didn't find anything that could be damaged.
      After that, I began voltage measurements, in which I noticed the absence of VDDQ, VDDP, VTT, and VPP lines. Later, I checked if there is an EN state on these lines,...
      03-15-2024, 10:46 AM
    • meraklinetx
      Asus Z97-a power cycle, no boot no cpu voltage
      by meraklinetx
      Hello, I have an asus Z97-A motherboard and it doesn't start which was working properly before, the problem isn't related by ram, ram slots or psu (I changed all and nothing work), the exact problem is when you switch it on , it starts and after 1 seconds (no boot or display picture) it's off and then on cycle continuously until you power it off from psu also it's responding to the power switch for turning it off if you keep pressing it 3 or 4 seconds (power button pin has 3.3v) , also when you start it with eatx 12v socket connected this is happening (power cycle also all voltages are resetting...
      05-10-2023, 06:08 AM
