Ideapad u310 no video.
  • esgeroth
    • May 2012
    • 18
    The unit powers on but nothing shows up on the screen. Same with external monitor. Every once in a while, maybe after turning it on and off 30 times or so, it starts up normally.
    I was going to try to flash the bios chip but the bios file I downloaded from the Lenovo website is larger than the capacity of the bios chip. The chip is an Winbond 8mb 25Q64. The bios file I extracted from the download is about 8.5mb. How do I get a usable bios file that fits on the chip?
  • mcplslg123
    • Jun 2015
    • 7262
    • india
    Re: Ideapad u310 no video.
    100% working dump. Try and post result
    • cyberhack
      • Feb 2013
      • 466
      • Uk
      If the ram is removeable then i would test with new ram.
      Had some odd faults with ram failed.
      • esgeroth
        • May 2012
        • 18
        Programmed the chip with the supplied bios. Booted normally 3 times in a row. I think its fixed. Thanks.
        • Fr33man
          BIOS file (.BIN) for semi-Bricked IdeaPad 3-14ALC6
          by Fr33man
          I soft BRICKED my Lenovo IdeaPad laptop (black screen with led lights on, responsive keyboard backlight, fans spinning) after messing about with a Github tool called Smokeless. I am now attempting to reflash the bios through USB, but I am not sure if I extracted the correct BIOS ROM file to flash, and I also could not find the correct file name to rename it to (GLCrisis.bin, GLCN.bin, Currom.bin??). In addition to attempting to reflash the Bios with a USB, I have also performed the following activities:
          *Novo button power on
          *Disconnected internal battery...
          09-23-2024, 01:16 PM
        • pcwhiz24
          Bricked Lenovo IdeaPad 3 14ADA05 Need BIOS file for FN+R Crisis recovery
          by pcwhiz24
          Model: Lenovo IdeaPad 3 14ADA05 81W0
          S/N: PF2BZS7D
          I was having issues with this particular laptop where the NVME SSD would disappear and would not detect unless I took it out and reconnected it, then it would detect for only for a minute then disappear from BIOS. I figured updating the BIOS was worth a try so I booted into my HBCD USB and downloaded the latest BIOS file for that exact model. I ran the executable and everything went smooth, it beeped and then when it restarted, now it won't post, just black screen with fan spinning.
          I already have a CH341A programmer...
          04-07-2025, 07:10 PM
        • iZakre
          HP Pavilion 15 bc400ns - Complete Black Screen - Only video on live usb
          by iZakre
          Hello everybody!
          To put you in context I recently replaced the battery from my HP Pavilion 15 bc400ns with a used one, everything was going good. The same day, I decided to update the BIOS, everything went good. The thing occurred after I let the battery drain iddling on Windows 11 for the second time to calibrate it that the screen did not turn on again, the computer was on but the screen did not turn, like it would not wake from hibernation. I decided to restart the computer but got no video.
          The thing is that I had installed TeamViewer and could log into the computer...
          02-19-2023, 02:27 PM
        • Forest79
          by Forest79
          07-23-2023, 07:39 AM
        • maanee11
          Help to get Lenovo BIOS bin file for Thinkpad T560
          by maanee11
          Hello Everyone,
          I have Thinkpad T560 Which has corrupted BIOS. I have acquired Ch341A SPI flasher to program the BIOS externally. I see that to program the BIOS, i need a bin file for the BIOS. I was able to extract the .exe file of BIOS from Lenovo given here in this link:
          https://pcsupport.lenovo.com/au/en/p...me=BIOS%2FUEFI
          In the extracted files, I see that BIOS containing file has extension .FL1 and I need to extract or convert it...
          05-15-2022, 11:59 AM
