Dell 3521 (la-9104p) laptop not charging battery
  • Sanjeewait
    • Aug 2016
    • 63
    • Sri Lanka
    Hi all
    I have a dell 3521 (la-9104p) laptop. It not charging battery.
    (2 second detect charging after not charging. power connector icon detect but bot charging)
    drivers reinstall
    replace charging ic. same error
    i/o chip re program same error
    anyone help me
  • Sanjeewait
    • Aug 2016
    • 63
    • Sri Lanka
    Re: Dell 3521 (la-9104p) laptop not charging battery
    Hi all
    drivers reinstall
    replace the charging ic. same error
    anyone help me
    • ktmmotocross
      Boardkiller
      • Feb 2014
      • 3578
      • slovakia
      checked charging signal and mosfets?
      • dspok
        • Jan 2014
        • 553
        • Nepal
        If it is "plugin but not charging" issue than you can use jumper from power connector psid to sio psid (pin 16).
        • Sanjeewait
          • Aug 2016
          • 63
          • Sri Lanka
          Can you send me a image
          • ravi_1617
            YY Solutions
            • Jan 2012
            • 343
            • India
            charging issue (This battery charging is temporarily disabled) LA-9104P
            replaced (ISL88731CHRTZ)
            • mcplslg123
              • Jun 2015
              • 7262
              • india
              Tried with a known good battery?? Adapter wattage detetced correctly??
              • ravi_1617
                YY Solutions
                • Jan 2012
                • 343
                • India
                Thanks for reply, yes tried it few adapter also ,same situation ,there is no BATT+ at all
                after flashing bios .now say ( battery cannot be identified )
                In beginning (PQ102 4407) found short.
                • mcplslg123
                  • Jun 2015
                  • 7262
                  • india
                  Seems like battery is damaged. Try with a known good battery first.
                  • ravi_1617
                    YY Solutions
                    • Jan 2012
                    • 343
                    • India
                    Thanks for your intrest.problem solved.One of 3 capacitors was short.replaced it. Now charging normal.like u said connected a charged battery there was no power at all.
                    • mcplslg123
                      • Jun 2015
                      • 7262
                      • india
                      Thats a very common fault on this mb-caps getting shorted on battery output line.
                      • Bowline
                        by Bowline
                        06-11-2025, 10:13 AM
                      • Thomasraud
                        Dell Vostro 3550 (v A01 with BQ24707) Plugged in, Not Charging
                        by Thomasraud
                        i have similar problem as https://www.badcaps.net/forum/showthread.php?t=37828
                        QUOTED
                        -It works on charger (without battery connected-only charger)
                        -It works on battery (without charger connected-only battery)
                        -& it also works when plugged in battery & charger, but it's not charging the battery
                        //Confirming, i have same issue, but problem started from charger, centre PIN is outputing 10V+ and jumping randomly 19V
                        and..
                        QUOTE
                        The IC cannot maintain the input current level
                        06-28-2022, 06:47 PM
                      • flat-earther
                        ASUS X54H laptop thinks it's always charging even with charger unplugged
                        by flat-earther
                        The charging indicator light on my ASUS X54H laptop is always on even when the charger is disconnected.
                        Windows also shows ''Plugged in'' when charger is not connected.
                        This problem started year ago gradually, when unplugging the charger the charging light took several seconds to disappear, then minutes, and now almost always on even when unplugged for an entire day.
                        Strangely, before sometimes immediately when plugging in the charger the charging light went away, and later came back with it connected.
                        If I let battery run out and say it has 3% Windows will...
                        06-24-2025, 09:32 AM
                      • Grucha98
                        Dell Latitude E7440 battery not charging only works on AC Adapter LA-9591P
                        by Grucha98
                        Hi, i have problem with dell E7440, battery is not charging. Idk all story. Original Dell Adapter broken up (its not give 19V) i guess first ac adapter broken up and it broken charging circuit in laptop. Laptop has clone battery (Green Cell)
                        Laptop works on clone adapter, and its not charging battery. Like on photo. I checked mosfets near battery plug. They are not shorted. But on PQ809 and PQ810 are low on diode mode (both 0.25V) I desoldered them and check on bench and they are good both 0.5V on diode mode. I checked only drain - source way. So its board circuit it should be higher,...
                        09-09-2024, 11:22 AM
                      • Robocop
                        Dell G3 3579 (LA-F611P) not charging
                        by Robocop
                        Hey guys,
                        I've seen several questions about this exact issue, but I've never found the fix, so I would appreciate if we can start over the whole debugging process again from start to finish, for my specific issue.
                        In the BIOS setup, (see pic) the AC adapter is detected with the correct power rating, the battery is stated as charging (when plugged in, of course), and the battery health is stated as "Excellent" (as expected, since this is a brand new battery purchased a couple of weeks ago). However, the battery never charges (the percentage never increases)....
                        06-25-2024, 08:15 PM
