K56cm fan always on and maximum speed after reprogramming
    Hi friends, I have flashed k56cm 2.0 but when power on the fan always to maximum speed, I have see on bottom of laptop, it's write k56CA, how it's possible to solve ? thanks
    Re: K56cm fan always on and maximum speed after reprogramming
    post that bios here
    Im Back... sort of...
      I have flashed whit BIOS take here https://www.badcaps.net/forum/attach...4&d=1461507773
        try this, it may not work at first try
        this hapens with me6 this is me8... did you look at cpu cooler for dust and change thermal paste and thermal pads...
          Thanks, I'll try Monday. I will put the new thermal paste. it means me6 me8? I'm sorry but I'm not a BIOS Programmer. Thank you so much
            Hi friend, I have tryed now, the fan work proplety but black screen and wifi and hdd led flashing simultaney
              Have suggestions for me ? Thanks
                hm yes,
                try this
                  nothing, it's same of previous bios, led flasing and monitor black. :-(
                    well the only way then is to try to flash me region within bios
                      please teach me, I don't say. what should I do
                      ? thanks
                        Hi friend, this is the dump of your bios file after power on the PC
                          Ok..I`ve rebuilt 2 dumps for you...both should work...first try number 1 than number 2 and post results...
                            I dont remember where i got this from try it and report
                            Remove cmos battery first and check.
                              If it's possible, post the code and version written on motherboard.
                              what is the reason why you have reprogrammed the bios?
                                I reprogram the bios because the chip eprom fault. I have buy a brend new bios chip and reprogram. the mb is k56cm 2.0 but on bottom of chassis are printed this information : k56CA
                                  Now I have program file number 1, I try Thanks
                                    Hi I have flashed the number one, the PC power on and display work propletly the fan are in stop and after 20 second go tu full power. Now I reprogramming with second file
                                      The correct bios is for k56cm, furthermore the only difference with similar models is the vbios that you can manage with mmtools.
                                      the speed of the fan does not always depend on the bios, check the gpu temp by changing the fan speed manually
                                        I have tryed any file but the fan always at maximum speed after 30 seconds. The temperature read on sensor by hdwmonitor is 35° C
