K56cm fan always on and maximum speed after reprogramming
  • magnetepazzo
    • Feb 2017
    • 85
    • italy
    Hi friends, I have flashed k56cm 2.0 but when power on the fan always to maximum speed, I have see on bottom of laptop, it's write k56CA, how it's possible to solve ? thanks
  • ala_borbe
    aka Donald
    • 1625
    • Malta
    Re: K56cm fan always on and maximum speed after reprogramming
    post that bios here
    Im Back... sort of...
    • magnetepazzo
      • Feb 2017
      • 85
      • italy
      I have flashed whit BIOS take here https://www.badcaps.net/forum/attach...4&d=1461507773
      • ala_borbe
        aka Donald
        • 1625
        • Malta
        try this, it may not work at first try
        this hapens with me6 this is me8... did you look at cpu cooler for dust and change thermal paste and thermal pads...
        • magnetepazzo
          • Feb 2017
          • 85
          • italy
          Thanks, I'll try Monday. I will put the new thermal paste. it means me6 me8? I'm sorry but I'm not a BIOS Programmer. Thank you so much
          • magnetepazzo
            • Feb 2017
            • 85
            • italy
            Hi friend, I have tryed now, the fan work proplety but black screen and wifi and hdd led flashing simultaney
            • magnetepazzo
              • Feb 2017
              • 85
              • italy
              Have suggestions for me ? Thanks
              • ala_borbe
                aka Donald
                • 1625
                • Malta
                hm yes,
                try this
                • magnetepazzo
                  • Feb 2017
                  • 85
                  • italy
                  nothing, it's same of previous bios, led flasing and monitor black. :-(
                  • ala_borbe
                    aka Donald
                    • 1625
                    • Malta
                    well the only way then is to try to flash me region within bios
                    • magnetepazzo
                      • Feb 2017
                      • 85
                      • italy
                      please teach me, I don't say. what should I do
                      ? thanks
                      • magnetepazzo
                        • Feb 2017
                        • 85
                        • italy
                        Hi friend, this is the dump of your bios file after power on the PC
                        • Djosla
                          • Dec 2012
                          • 246
                          • Montenegro
                          Ok..I`ve rebuilt 2 dumps for you...both should work...first try number 1 than number 2 and post results...
                          • cyberhack
                            • Feb 2013
                            • 466
                            • Uk
                            I dont remember where i got this from try it and report
                            Remove cmos battery first and check.
                            • jasko_jacker
                              • Oct 2014
                              • 1140
                              • italy
                              If it's possible, post the code and version written on motherboard.
                              what is the reason why you have reprogrammed the bios?
                              • magnetepazzo
                                • Feb 2017
                                • 85
                                • italy
                                I reprogram the bios because the chip eprom fault. I have buy a brend new bios chip and reprogram. the mb is k56cm 2.0 but on bottom of chassis are printed this information : k56CA
                                • magnetepazzo
                                  • Feb 2017
                                  • 85
                                  • italy
                                  Now I have program file number 1, I try Thanks
                                  • magnetepazzo
                                    • Feb 2017
                                    • 85
                                    • italy
                                    Hi I have flashed the number one, the PC power on and display work propletly the fan are in stop and after 20 second go tu full power. Now I reprogramming with second file
                                    • jasko_jacker
                                      • Oct 2014
                                      • 1140
                                      • italy
                                      The correct bios is for k56cm, furthermore the only difference with similar models is the vbios that you can manage with mmtools.
                                      the speed of the fan does not always depend on the bios, check the gpu temp by changing the fan speed manually
                                      • magnetepazzo
                                        • Feb 2017
                                        • 85
                                        • italy
                                        I have tryed any file but the fan always at maximum speed after 30 seconds. The temperature read on sensor by hdwmonitor is 35° C
                                        • Babbar
                                          1980s Holz Her 2420 belt sander - Only works when speed control at maximum
                                          by Babbar
                                          My fathers belt sander from the 80s which i very much would like to continue using has an issue with the speed control. The machine works fine on maximum speed but will not turn or give any sign of life when on any other setting. The speed control is a dial going from 1-6 although implemented as a potentiometer without distinct steps. I took the machine apart and measured each component individually, all components and measurements have been captioned in the attached pictures. The Triac did not get identified correctly using my cheapo component tester, i don't know if this is user error, if the...
                                          11-13-2024, 01:54 AM
                                        • japlytic
                                          Maximum speed should be marked on network ports
                                          by japlytic
                                          I noted that a number of consumer entertainment devices have the maximum speed marked on the wired network port and considering that there are broadband plans faster than 100 Mbit, the wired network port can be a bottleneck since some routers do not have Gigabit (only 100 Mbit) support for the WAN port let alone the wired network ports.
                                          One other thing: Certain low cost network cables only have two pairs which limits speed to 100 Mbit.​
                                          12-19-2024, 05:04 PM
                                        • tofik
                                          MOSFET equivalent K8A60DA
                                          by tofik
                                          Hello guys,
                                          I have a shorted MOSFET K8A60DA with the following characteristics:
                                          Type Designator: TK8A60DA
                                          Marking Code: K8A60DA
                                          Type of Transistor: MOSFET
                                          Type of Control Channel: N -Channel
                                          Maximum Power Dissipation (Pd): 45 W
                                          Maximum Drain-Source Voltage |Vds|: 600 V
                                          Maximum Gate-Source Voltage |Vgs|: 30 V
                                          Maximum Gate-Threshold Voltage |Vgs(th)|: 4 V
                                          Maximum Drain Current |Id|: 7.5 A
                                          Maximum Junction Temperature (Tj): 150 °C
                                          Total Gate Charge (Qg): 20 nC
                                          Rise Time (tr): 25 nS
                                          Drain-Source
                                          07-19-2023, 05:18 AM
                                          DELL Vostro 3580 Notebook 3000 Specification for Upgrade or Repair
                                          This specification for the DELL Vostro 3580 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3580 boardview and 3580 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro 3580 Notebook...
                                          09-06-2024, 09:17 AM
                                          DELL Vostro 3581 Notebook 3000 Specification for Upgrade or Repair
                                          This specification for the DELL Vostro 3581 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 3581 boardview and 3581 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for DELL Vostro 3581 Notebook...
