K56cm fan always on and maximum speed after reprogramming
    Re: K56cm fan always on and maximum speed after reprogramming
    35° with fan at maximum speed but if you stop the fan for a moment and it reach ,for example, 90° C instantly , probably there is an issue with gpu.
    You can try another method, install msi afterburned and change the freq of the videocard at his minimum; in this case the temp must go down but not with a fault.
      those dumps and me region is ok...culprit is somewhere else...might be something with sio...
        @Djosla
        my clean me dumps are not working... how did you do yours with fitc or hex editor?
        Im Back... sort of...
          you have pm...
            Hi friends thanks to all for help, and to end I have put a resistor to power of fan and have reduced the noise . Any dump I have tried haven't resolve the problem. Thank to all.
