VPCEH (MBX-247 HK1) turn off immediately in gpu stress test
  • r ez a
    • Sep 2014
    • 39
    • iran
    hello my friends
    i have a laptop here that its true everywhere,except gpu works
    when i run gpu stress test(furmark) it turnes off instantly
    i try different windows and drivers
    i change cpu,ram,bios
    i replace vga chip
    but nothing changed
    what else can cause this problem?
    tnx for ur help
  • koby058
    • Jan 2017
    • 387
    • israel
    Re: VPCEH (MBX-247 HK1) turn off immediately in gpu stress test
    gpu over heat?
    • r ez a
      • Sep 2014
      • 39
      • iran
      Originally posted by koby058
      gpu over heat?
      nope,temperature is normal
      about 60 degree
      it never run the test even for a sec
      when i click to run,it turns off!
      • boyebaran
        • Sep 2015
        • 249
        • iran
        Hi reza
        i think you have I/O problem.
        • m1ch43lzm
          by m1ch43lzm
          05-12-2025, 08:37 PM
        • pajdek
          Lenovo Y700-17ISK turn on and off
          by pajdek
          Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
          09-20-2023, 02:49 AM
        • ThetraXXL
          LG OLED C1, SOS-Turn Off, Stand alone test
          by ThetraXXL
          Hello guys,
          I recently picked up an LG C1 in 65 inch size. Previous owner told me that the TV won‘t start, so I did believe due to PSU issue, but not this time. I could narrow it down to the T-Con or Panel.
          PSU and Mainboard work both like intended, all Voltages available, Optical on when T-Con lower Ribbon is disconnected and I even managed to get some picture with P-Only, IN-STOP cycle but only for 2 sec. before shutdown.
          For the stand alone test the panel starts with some flashing horizontal white lines and then continues to build up some color on the...
          10-29-2024, 10:33 AM
        • Inforgalaxie
          Overheating in Stress Test
          by Inforgalaxie
          Hello i have a problem, i have a laptopt Dell E5570 that in stress test without the battery it works good and not turn off.
          But when i conect the battery and made a stress test the cpu temperature go to 95º and turn off. I also was testing with a new battery and the problem is the same in stress test turn off with big cpu temperature (95-100º). What can be this?
          12-13-2023, 03:24 AM
        • chth96
          How Can I test PWM DM0365R?
          by chth96
          Hello
          I have power adaptor(220V/input, 12V 1.2A/output) which has symptom of fluctuating output DC voltage between 11.5V-12.2V.
          So I opened its plastic case and when switched it on, I heard constant tik tik sound from inside its PCB.
          I measured DC voltage between negative and positive pin of the largest capacitor(400v 10uf) and it was measured contant 300V.
          I also measured ESR value of all capacitors and I noticed that one of capacitor(KMG 16v 470uf), which located in the secondary side, have high ESR value(10 ohm),So I replaced it with same specification NXH capacitor....
          06-18-2025, 04:14 PM
